spark plugs shorting out
Old 03-23-2004, 09:00 PM
flat black beast's Avatar
flat black beast
flat black beast is offline
Hey everyone, does anyone know what would make a spark plug spark to the engine block while it's in place. I tried new everything and I still see blue glow at the base of the plugs.
Old 03-23-2004, 09:12 PM
78fordman's Avatar
78fordman
78fordman is offline
I assum you replaced the wires and plugs. CLean up the threads a little bit with some wd-40, work the plugs in and out a bunch of times.
Old 03-23-2004, 09:44 PM
faroffthetrack's Avatar
faroffthetrack
faroffthetrack is offline
are the electrodes clean? is the plug wire in all the way? are you sure there the right plugs? tightened to spec? did you use silicone dielectric compound?
Old 03-24-2004, 04:00 AM
flat black beast
yes I did it all . I tried new plugs and then the old ones and noticed the same problem.
Old 03-24-2004, 09:00 AM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
Could be a cracked spark plug. The spark will find the easiest path to ground, and through a crack to the block can be easier for it than jumping the gap. Be careful not to drop plugs when installing them and don't use any that you do drop.
Old 03-26-2004, 06:37 PM
Silver Streak's Avatar
Silver Streak
Silver Streak is offline
That happened on #3 the last time I did a major tune up on my truck. It ate 3 spark plugs on that cylinder within a week. I spent a bunch of time trying to find out why, then on the 4th plug it ran fine and I quit messing with it. I'm guessing I got a bad batch of plugs because they all came from the same box. I returned all of them and the new box worked fine. Some butt head from Wal-Mart probably dropped them while he was stocking.
zech
1983 - 2012 Ranger & B-Series
09-18-2015 09:25 AM
makthenif
1997 - 2003 F150
04-24-2014 08:49 AM
mainman
2004 - 2008 F150
07-25-2009 12:15 PM
longbowhunter
03-29-2008 12:44 PM
07-11-2001 04:55 AM
Quick Reply: spark plugs shorting out
