F250 Bolt Pattern
The bolt pattern is 8x6.5". Most 3/4 tons and one tons from Ford, Chevy and Dodge used that bolt pattern from the '70's through the late '90's.
The difference between Chevy and the other 2 is the size of the center hole. If I remember this correctly, Chevy wheels had the smaller dia center hole, so you can use a Ford or a Dodge wheel on a Chevy, but a Chevy wheel only fits on Chevys. It could be the other way around on the center hole size, my memory isn't what it used to be, but I think I got it right.
'02 should be metric.
My question is, I have a '97 F250 Superduty, what is the bolt pattern on the '97/'98 models? I think it's still standard 6.5 pattern, but I can't find much info on these two year model trucks. I even have to ask for parts for a '96 when I go to the parts stores or they give me the wrong parts!
Ford stopped making F-250's in late 1997, and they used up all the leftover parts from 1996 in doing so. 1997 F-250's that look exactly like the 1996 trucks *are* the same truck. All parts will interchange and they have the SAE 8 x 6.5" lug pattern.
In 1998 Ford made a light duty F-250 that looked just like the 1998 F-150. The only easily visible differences are the badges and the lug pattern, which is a very bizarre 7-lug wheel. I don't know what the pattern is, but it's the only 7-lug pattern I've ever seen.
In 1999 Ford came out with the redesigned superduty with the more aggressive looking front end and metric lug pattern.
OK, thanks for the info. Mine does look just like a '92-'96 model, and it does say Superduty on it under the F250 on both sides. Though from what you said, I'm sure it was installed aftermarket. Anyway, I didn't understand why '97-'98 SD/HD trucks had the old body style. That clears up a lot. Guess now anytime I order something for my truck I'll just tell them it's a '96.
As far as I know they will fit. They should still be 8x170mm.
Oh, an update: I bought a set of OEM Dodge wheels to put on my truck and found out the center hole is just slightly too small for the Ford axles. In fact, I didn't find out until the next day when I could hear my brake drums rattling because the wheels wouldn't tighten up all the way.
These sorts of tools might be helpful to any vehicle owner:
bolt pattern gauge | eBay
I swear I bought one of the black caliper types from FleaBay a while back for less than $10 each brand new-----can't find that same deal now though!
Some of these are exactly what tire shops etc use----they'll do it all!
16.5" to 16" on a 1975 F-250?
I bought a 1975 F-250 and the guy gave me a set of 16" rims and tires to go with it, since the 16.5" tires are being phased out by most dealers and the 16's are easier and cheaper to get. Any way to make a long story short instead of being the 8 6.5" bolt pattern these new rims are the metric 8-170's. So now I need to find some 16" rims that will fit my truck. I know that the GM 8 lug rims have a 6.5" b.p. but is the center hole going to be large enough? Any help will be appreciated.
Thanks
John K.
Thanks
John K.
