Interchangable seats?
Hi Lynn. Welcome to FTE.I have the same problem you do,trying to fine a replacement that is.The problem I'm having is locating one then finding a good one,not all ripped up.lol.I'm ordering a kit to replace the seat covering.It's a little over $100.If you can't find one,this may be an option .Good luck with your seat problem.
Originally Posted by mr4speedford
any stock seat from a 57-60 f-100 -f600 should bolt right in. If your looking for a later model seat, I can't help you there. -4speed
Lynn
Someone put a different seat in my truck, and i think it is from a 79 F250. I say that because i found a build sheet under the seat springs and somewhere i determined it to be a F250. It's a bench with a split back rest and it fits but with only an inch on either side of the top seat back in rearward position.
fifty-two_f1
08-05-2010 10:11 PM
lud04X
03-02-2008 12:39 PM
