crown victoria no start (4.6) - Ford Truck Enthusiasts Forums
Old 03-23-2004, 12:41 PM
Squiggy Squiggy is offline
Squiggy is starting off with a positive reputation.
hey guys Im working on a crown victoria, I got no spark and no fuel pump initiation as I turn the key on the dash. I have a new computer that worked in a different car. I cant communicate with any of it. I hook the genysis scanner and it wont read a pick up from computer. Thanks for any input as its greatly appreciated
Old 03-23-2004, 08:46 PM
281Cammer 281Cammer is offline
281Cammer is starting off with a positive reputation.
Hey I also have a problem on a 92 crown victoria and was hoping that any 4.6 experts have some tips. When I crank my engine it turns over but wont start, it has compression on all cylinders but when it cranks it cranks real rough and has no oil pressure, thats all i can describe any help would be gladly apprecaited.
Old 03-23-2004, 11:41 PM
SMiller SMiller is offline
SMiller is new and has a neutral reputation at this point.
Need to know what year the car is Squiggy, are you sure the ecm you got is good? Kinda hard to not get it pluged in right, but worth taking it back out and reinstalling it, is the ecm from the same year car? Only two years were interchangable the '96 and '97s If you got it from the junk yard I would go back and swap for another one, might grab a P71 ecm (police computer) slightly firmer shifts, raised fuel limiter, raised shift points, much higher speed limiter.
Old 03-24-2004, 09:42 PM
The year is 1998. It was a police car, but swapped to be a cab. I got compression, no spark and no fuel charge plus the computer cant communicate with it. Ill check for the P71 model. I got power and grounds to all needed places... I figure the problem lies in something with it operating both things. The dude said it wouldnt start after he drilled screws into his door. I pulled the panel off to see if any wires were chafed but no such thing. I unno The theft system might do it. ???
Old 03-24-2004, 10:56 PM
I would again say a bad ecm, I don't know if we are allowed to post links but if you do a search or ask on crownvic.net you WILL be dure to find the awnser, sorry I couldn't be of more help. P71 is police interceptor, if you put a regular crown vic ecm in your police interceptor that would be a back step, I would try and stay with the P71 ecm if I could, might also want to post in the computer chips section here on FTE, Ken or one of those guys might be albe to get you in the right direction. I don't think pats has anything to do with it, although if the ecm you put in it had pats it might be in a saftey setting and not allowing fuel\spark since your P71 doesn't have pats, best of luck!
Old 03-26-2004, 10:11 PM
Well I found out. It was a Wire shorted to ground. It was in the diver side back door. Shorting all voltage to ground.
I6 on a crown vic swap Santiagoeford 1961 - 1966 F-100 & Larger F-Series Trucks 8 01-07-2017 04:49 PM
Advice needed Jafo56 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 12-26-2015 12:26 PM
front end swap Catfishoimc 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-14-2014 09:19 PM
1986 F 250 Speakers 86ford185 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 02-12-2012 04:28 PM
1991 Crown Victoria 140mph Speedometer swap into 1992 F-150 SideWinder4.9l 1987 - 1996 F150 & Larger F-Series Trucks 38 09-21-2011 06:40 PM
Tags
2003, 46, 94, 96, computer, cranks, crown, ford, location, pats, start, vic, victoria, victria, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
