oil in throttle body - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 03-23-2004, 09:37 AM
03Harley 03Harley is offline
03Harley is starting off with a positive reputation.
Angry oil in throttle body
Anyone have a supercharged 5.4 have any problems with oil. like always having to add oil and oil all over inside throttle body?
Old 03-23-2004, 06:42 PM
ltrripp11 ltrripp11 is offline
ltrripp11 is starting off with a positive reputation.
yes, i have a 2001 lightning that does the same. i dont have all the answers on it but apparently its a design flaw with the p.c.v.system causing this under boost conditions. i saw a kit that allegedly rectifies this on e-bay under parts and explains the situation somewhat!!! im reluctant to pop for it though and sort of looked at it as a sales pitch without any real proof it works behind it. good luck.
Old 03-27-2004, 11:33 AM
I just had a frind of mine (hes a mechanic ) take my intercooler out and clean it. What a oil coated nightmare oil coated everything he even said he couldnt beleive what a bad design by ford. I also installed a oil seperator from razors edge and after only 30 miles I had about a teaspoon of oil in the bottom. For $50.00 I think its a good investment.
Old 03-27-2004, 12:28 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
sounds like a great idea harley. =)
Old 03-27-2004, 01:54 PM
harley, where exactly did you place the oil seperator?? between pcv valve and hose to intake i assume?? also where is razors edge??. thanks.
Old 04-17-2004, 01:58 AM
03HDtrucker 03HDtrucker is offline
03HDtrucker is starting off with a positive reputation.
Thumbs up Oil separator
03Harley, does Razors Edge have a website? I'd like to get one of these for my 03 HD.
Old 04-17-2004, 02:07 PM
2002BLGT 2002BLGT is offline
2002BLGT is starting off with a positive reputation.
just so you guys know , if oil gets on your mass air meters if you are having this problem , it will cause your trucks to run LEAN which is bad , make sure to clean it out with brake cleaner and fix the pcv issue , or install breathers in the valve covers , www.modularfordpowerhose.com , this guy has had experience with this problem and has access to some nice breathers for the valve covers .
Old 04-18-2004, 02:08 PM
mitch5170's Avatar
mitch5170 mitch5170 is offline
mitch5170 is starting off with a positive reputation.
From what I know the problem is caused by going into boost then releasing the throttle quickly, causing the intake to suck oil thru the pcv system. You can purchase a oil seperator system from several sources. Go to NHTOC.com and do a search for this same topic, you will a truck load of info!
Oh...and I dont believe its as easy as adding valve cover breathers...unless you have your pcm reprogrammed Im pretty sure it will set a code.
Heres some links to vendors that sell the kit...
http://www.lightningforceperformance.com/home.html
http://www.razorsedgemotorsports.com/
http://www.johnnylightningperf.com/
http://www.teamjdm.com/
Old 04-21-2004, 10:10 PM
breathers
I wrote an email to Lightning Enterprise regarding breathers and this is the reply I got:
Personally I have tried it both ways...only no one seems to ever know what
figures to use when allowing for the corrected air entering the open
breather and into the air / fuel ratio.
I have dyno tested with the breather and found that without correcting for
the supposed added air that enters the equation that there is a small amount
of leaning out through mid range RPM but that it equalizes by 4500 - 5000
and doesn't seem to cause detionation during the lean period what so ever...
No I would not reprogram my PCM...besides what figures would you use anyway
as I have no knowledge of any being comprised...
So what are your thoughts on this?
Old 04-25-2004, 09:08 PM
so what do you think?
14 f150 5.0 oil in intake Jr_f150 2009 - 2014 F150 1 04-21-2016 02:31 PM
Losing Oil? ZachManXLT 1997 - 2003 F150 3 02-04-2016 11:34 PM
Burning oil through PCV system? Pele Excursion - King of SUVs 17 06-13-2015 02:43 AM
oil leak at VCT cap seal jkinghorn6.0 Modular V8 (4.6L, 5.4L) 0 04-07-2014 09:46 PM
oil buildup in intake????? ecolandscaping17 1999 to 2016 Super Duty 11 02-02-2014 08:18 AM
Tags
03, 1994, body, davidson, edges, f150, ford, harley, kit, lightning, oil, razors, separator, throtle, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
