Rocker Stud Size?
Rocker Stud Size?
Anyone know the rocker stud base size that will fit my 1968 Lincoln 460 heads? Planning on putting Comp Cams Pro Magnum roller rockers on it. Part #1330-16. I know I will need hardend pushrods and guideplates. I just cant find any info on what size the base of the bolt is. The rollers need 7/16" stud. Also what is the stock pushrod length? I have read I will have to get pushrods for a SCJ, since I will need a longer pushed with the roller rockers.
When I put threaded studs in my 1969 DoVE C heads for Harland Sharp roller rockers, the long length Ford units from Crane Cams were not long enough. I ended up getting BB Chevy studs that were long enough. They have worked out fine for me. JEGS technical help guys suggested that to me. Best of luck.
bigdan1979f-250
02-02-2010 04:25 PM
grumpy44
10-03-2004 07:54 AM
f100guy
09-05-2004 03:41 PM
