Does it still make satisfactory cold, aside from wanting to stall?
If so, there is a fast idle solenoid that may not be working.
It is a crap shoot from here out. After all, it is a 15 year old system. I would rule out R-12 unless you live on the mexican border.
If it is not making cold anymore... I would verify the compressor works, find and fix the leak, change the dryer, and install some Freeze 12. This is cheapest. (Look for crap when you change the dryer in the lines and make a judgement call.) When the compressor goes, then do the conversion to R-134.
A/C work is a can of worms... everthing has to be perfect. It was easy when R-12 was a $1.00 a pound and systems used hose clamps and it was OK to purge the system with freon. It is a whole new ball of wax. R-134 is over $5.00 a lb and does not perform as well as R-12. Cleaning solvents cost more... 1-1-1 triclor is gone... now they want to sell you some stuff for $20 a flush and it is a crime to vent refrigerant.
If you can afford to, take it to a shop. If you can't, read everthing you can, buy some guages and a book, and then phone a friend who does it for a living because you will still have questions. Feel better now?
