Opening the dash for stereo install in XLT????
I've seen the directions for removing the cover from the factory stereo, however, every set of pictures I have seen show an ashtray. My 04 XLT doesn't have an ashtray. In it's place is some sort of empty box looking thing.
Hopefully the pic works, so everyone can see what I'm talking about. How do you get this thing off?
okay, be very careful but this is how I did it. I took a dull butter knife and stuck it in the slit between it and the tray at the top. Pry it back until the clips pop, then grab the top with your hands and slowly work it down pulling where you feel the clips. The entire thing is held in by those pressure clips so just pull all the way around. It seems pretty tough like you can't break it. I've taken it off maybe 5 or 6 times. The stereo is held in with...I think M5 hexes. oh one thing, to remember is when you get the top part away there is a wire to the airbag light right at the top, make sure to disconnect it and not rip it out. Then there is 2 or 3 other wire harnesses, but they are longer.
hope that helps.
-ii
hope that helps.
-ii
Right. Just pry it off with a butter knife or a flat head screw driver. You may want to put a piece of masking tape around the end of the tool you're using so you don't scratch any of the plastic. It comes off very easy. Just start at the bottom. Once you get the bottom popped off you can do the rest by hand. It's pretty durable.
Once you have the panel off you'll need a 7mm socket or nutdriver to remove the radio screws.
Originally posted by Mick68
Looks like they put an XL dash in your truck.
All the XLT's I've seen have the ash tray cup holder pop out tray.
Fine if you don't smoke, but I like to keep my crack pipe in there.
-ii
Front speakers are cake. Get a butter kinfe, or a screwdriver with tape on it.....locate the notch on the speaker grill and pry underneath it. then slowly work your way around prying behind every clip until the whole thing is off. to replace just line it up and press it back in.
The rear ones depend on your cab type.
-ii
-ii
