Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-22-2004, 04:28 PM
F250reddog is starting off with a positive reputation.
low side service port 100 PSI?
My truck always had excellent air conditioning. It got very cool very fast--no complaints. I recently had the engine replaced and they must have lost all the refrigerant and didn't refill it because now AC is same as vent. So I get a recharge kit from Wally World and hook it up to the low side service port and the gauge reads well in to the red, about 100 PSI. What the heck does that mean. My first thought was that it was connected to high side but I pulled out the service manual to verify I was hooked on low port. What color should the cap on the port be? This port was metal with a black cap. There was aonther "port" with a green cap but the port and threads are pastic. I tried hooking the gauge to this port but It didn't seam to fit well. I sure would like my great AC back. Any ideas???
__________________
'99 F-250 SD Lariat, 4x4, V10, Auto, SC, SB, 35X1250X16.5 BFG AT KO's, Rancho RS9000X
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-22-2004, 07:31 PM
Ecuri is gaining momentum as a positive member of FTE.
What is this truck?
The high side hose is usually smaller and the low side hose is usually larger.
You need to pull a vacuum and see if it holds.
__________________
78 F150 408 4v valves/C6
77 F250 390/NP435
99 Explorer daily driver
  #3 (permalink)
Old 03-22-2004, 11:31 PM
Sorry, I didn't realize that my signature was no longer posting. The truck is: '99 F-250 SD Lariat, 4x4, V10, Auto, SuperCab.
My manual shows the low side being right on top of the Suction Accumulator/Drier. After further reading in the manual it looks like PSI on the low port can be anywhere from 50 to 450. Does this sound right? The manual that came with the guage I have says anything in the 100+ range is "Red" and considered problematic. I'm confussed
__________________
  #4 (permalink)
Old 03-22-2004, 11:48 PM
Man, I am too!
That sounds right... the dryer is always on the low side.
50-450 sounds insane!!!! Like 30-50 would sound normal to me.
Sorry, don't know about that truck in particular, but A/C is A/C and R-134 is R-134 whatever it is in.
You got 100 PSI with it running, compressor on?
It is important to know the differential pressure... this is where cold is made.
__________________
77 F250 390/NP435
  #5 (permalink)
Old 03-22-2004, 11:51 PM
I made the check with it running and MAX A/C on high. I don't know for certain that the compressor was running. Maybe something is broke and I need more than a recharge.
__________________
  #6 (permalink)
Old 03-23-2004, 12:02 AM
Have someone cycle it on and off and see that the clutch engages... 100 PSI might be the static charge. Even if it has air in it the pressure will change when the compressor comes on.
__________________
77 F250 390/NP435
  #7 (permalink)
Old 03-23-2004, 12:20 AM
Thanks I'll give it a try
__________________
  #8 (permalink)
Old 03-23-2004, 10:16 AM
94van is starting off with a positive reputation.
You're gonna have to get a set of "Real" gauges on the system to do it right. If they opened the system up, it will need to be evacuated before recharging, and you should probably replace the accumulator/dryer while you're at it.
Make sure your Wally Mart R-134 DOES NOT have stop leak in it, or you'll ruin the system.
__________________
'94 E-150 Conversion Van 4.9 / C-6
'89 Mustang 5.0 - Original Owner
'06 Mustang DeLuxe V-6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
