exhaust manifolds glowing red?!?
I recently bought a 1989 f-250 with a 5.8. It hsn't run right since I bought it, but that is the reason I got it at a great price.
Here is the run down:
EGR sticks so I disconnected the vacuum and now it idles nice. I gutted the cat, replaced the fuel pressure regulator and o2 sensor as well as a top to bottom tune up and although its running much better its still got no power and gets the manifolds red hot.
FWIW, it has all the air tube junk running to the manifolds. It seems to have a leak in the drivers side manifold but my mechanic tells me its a freeze out plug in the front of the head.
Any ideas as to why this thing runs like crap and is putting so much heat to the exhaust
through a lot of tinkering, I found a few things. The timing was off enough to drain some power, with that adjusted it would still make the manifolds glow. I unhooked the air tubes and no more glowing exhaust. I plugged the tubes for the time being, that is until I get the headers I just ordered from summit
Thanks for all of your help!
jarrettseiple
06-14-2015 09:58 PM
truknut1972
30
02-18-2010 09:58 PM
MRStace84
01-09-2003 09:39 PM
