Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-22-2004, 12:33 PM
ducboy is starting off with a positive reputation.
A/C not cycling - no heat either
I have a 2000 Mazda B2500 with a 2.5 liter four cylinder. 2 wheel drive, manual trans with A/C. My A/C compressor will not cycle regardless of the setting and there is no heat when I attempt to use it. Checked all fuses and relays. Swapped known good relay to the A/C circuit. Still no-go. Consulted my Haynes manual and found little help. Cant determin which is the WOT relay. Manual says to check this. Read another thread that one user said he replaced the "low pressure switch"
Anyone have some help here??
Thanks in advance.
P.S. I'm in Wisconsin and I'm freezin' my #*&! off.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-22-2004, 08:39 PM
Ultramagdan's Avatar
Ultramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to behold
Have you checked to see if the compressor is cycling and if the hoses to the heater core are hot? I would suspect a blend door problem if the rest of the system is ok.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
