Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-22-2004, 12:56 AM
97GreenRanger's Avatar
97GreenRanger is starting off with a positive reputation.
97 Ranger AC Question
I recently replaced the serpentine belt on my 97 3.0 4x4 extended cab. The old belt was pretty loose and would squeak on humid days. The new belt feels very tight.
Before the belt replacment the AC worked great. After the replacement the AC doesn't seem to work at all. On top of that I noticed that the engine will rev up a little when the compressor kicks in and then it drops back down to whatever RPM it was at before.
Could these problems be caused by a belt that is too tight or is something else going on?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-22-2004, 08:33 PM
Ultramagdan's Avatar
Ultramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to behold
Hello 97GreenRanger and Welcome to FTE!
I think you have something else going on. Have you checked to see if the compressor is engaging?
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #3 (permalink)
Old 03-22-2004, 08:42 PM
Thanks for the reply!
No, I haven't checked to see if the compressor is engaging, how would I do that? This is the first vehicle that I have ever owned with AC so I don't know much about it.
Is it possible that the refrigerant level is low?
Also, I had a friend at work who knows a lot more about cars than I do check the serpentine belt and he says that it is fine.
  #4 (permalink)
Old 03-22-2004, 10:34 PM
When you turn on the AC, the compressor will click and you will see the pulley engage. You can turn on the AC, get out of the cab and watch it cycle.
If the freon is low it can cycle rapidly but yours is new enough that it should shut itself off to avoid damage.
A pressure check of the system may be in order.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
  #5 (permalink)
Old 03-23-2004, 05:38 PM
Thanks for all the info.
It looks like the compressor isn't engaging for some reason.
I'll do the pressure check and go from there. If the pressure is fine where would you go from there?
  #6 (permalink)
Old 03-23-2004, 08:22 PM
I would suspect a electrical relay then.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
