460/429 transmission possibilities
I heard on a transmissions website that the C6 can only handle up to about 600hp even when kitted up and that the C4 is actually stronger.
I have a 429 I am putting into an Australian car which currently holds a 351C with a C4. I originally was going with a C6 for the transplant , but now I'm not so sure, as the 429 will be putting out around 600hp at the flywheel. Do you guys think the C6 will have problems?
I heard somewhere that the 351C has the same bellhousing bolt pattern as the 460/429's. Does this mean the C4 will bolt straight up? I can't imagine it, but this is my first effort with a big block, so enlighten me people.
Thats what we're here for
www.broaderperformance.com is a good link for a competent builder who knows what it takes to set up C-6s for real horse.
"Now I have a question, will any tranny with the correct bolt pattern, such as one off of a 351m or a 400, bolt directly to a 460?"
Yes. The bolt pattern is the same. However, there are differences with the torque converters. Some have a different sized pilot ****. Just use the correct converter for the engine.
jmss123
31
06-05-2023 10:14 PM
XB_Aust
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
16
04-03-2004 05:12 AM
1972, 390, 429, 460, bb, bolt, fit, ford, options, pattern, transmision, transmission, transmissions
