Stealth intake hitting carb?
Old 03-21-2004, 05:21 PM
Powergod's Avatar
Powergod
Powergod is offline
I have a Stealth intake on my truck and a Demon 850 carb. The butterflies on the carb are hitting the seperator on the top of the intake. What did you guys do to solve this problem if you had it. I was thinking of grinding it down a little. Help.
Old 03-21-2004, 08:32 PM
greenhighboy's Avatar
greenhighboy
greenhighboy is offline
I have got the wrong base gasket before and the holes were to small. I can't imagine the butterflies hitting on the intake.
Old 03-21-2004, 11:02 PM
proeliator's Avatar
proeliator
proeliator is offline
I don't see how it could actually be a butterfly/plenum interferance either. However, if it were, a 1/2 open spacer would be your easiest fix.
Old 03-22-2004, 12:38 AM
cid473's Avatar
cid473
cid473 is offline
A 1/2 or 1 inch spacer is actually a good idea, as it will solve your clearance probs, and give you a little hp and tq.
Old 03-22-2004, 08:25 AM
Hired Gun's Avatar
Hired Gun
Hired Gun is offline
I really doubt it is hitting the butterflies. On mine a piece of the fast idle linkage was hitting the passenger side of the intake. I just took a felt marker and outlined the problem and taped up the intake and ground it out with a die grinder. Look under the carb on the passenger side while working the throttle and you will see the problem. I wouldn't put a spacer on a Stealth.
Old 03-22-2004, 11:58 AM
proeliator's Avatar
proeliator
Thats a pretty broad statement isn't it? It all depends on the tune of the engine. On a 460 bone stock other than the intake, maybe not. On the other hand, I know no less than six guys with 460s and stealths who gained hp on the dyno through tuning with spacers and adding them in the range of 1" to 2". I myself use a 2" HVH which conventional wisdom should have hurt my bottem end, but actually helped the entire spectrum. Its all about the combo...
Old 03-22-2004, 12:46 PM
fordtrkpuller's Avatar
fordtrkpuller
fordtrkpuller is offline
FTE *******
1" spacer on the Stealth is a for sure good thing. Its been covered and proven a thousand times......use the search function on the 385 forum http://www.network54.com/Forum/85220
Old 03-22-2004, 02:07 PM
proeliator's Avatar
proeliator
Indeed. And that forum should be included in everybodies bookmarks. Its where I get all my hardcore 385 tech.
Old 03-22-2004, 04:27 PM
Hired Gun's Avatar
Hired Gun
With this kind of endorsements I will definetely have to give it a try. I have both a 1 and a 2" spacers laying around from my race car. Just looking at the huge size of the ports on a Stealth I figured a spacer would kill the bottom end throttle response and defeat the dual plane effect.
Old 03-22-2004, 04:47 PM
proeliator's Avatar
proeliator
Yea, its funny Gun, you look at the sewer pipe sized ports on the stealth and ya figure a spacer would do nothing but slug up the velocity. Yet, for some strange reason most of us have found gains with spacers with the Stealth. Go figure. Play around and let us know how it worked for you, too.
Old 03-22-2004, 05:02 PM
fordtrkpuller
FTE *******
Dont quote me on this...but I think I saw it explained once like this....The runner voluum to plenum volume is not quite on the money, but if you add the 1" spacer and increase the plenum voluum you hit thweet spot. I know Gary Blair has dyno proven this, and a few others have as well, I just dont recall the names and threads. Yes, that forum is hands down the very best group to ask hardcore 385 questions to, many of the guys that troll and respond there are professional engine biulders, or very serious racers/hobbiests. One day I hope to be the later and have gathered enough to actually share wit with those guys. For now I troll there :]
Old 03-26-2004, 01:32 PM
Powergod's Avatar
Powergod
Powergod is offline
well, I guess I will be ok. I put a 1" spacer in to solve the problem. I guess that was a good thing. The truck has not been ran yet. We will see what happens.
Old 03-26-2004, 02:29 PM
Bajajet's Avatar
Bajajet
Bajajet is offline
My 850 primary butterflies hit my Stealth too. Used a spacer to fix it till the intake was off. Then I relieved the egdes to clear.
Old 03-26-2004, 03:33 PM
Powergod's Avatar
Powergod
Powergod is offline
That is exactly what I had planned on, but now that I see that everyone says that a 1" spacer helps, I will just leave it on. Thanks everyone.
ryanwiss
05-13-2013 01:43 PM
jssparkyjr
05-02-2013 11:10 PM
ironhead86
31
04-06-2011 07:31 PM
ranger429
Engine Swaps
05-09-2004 07:04 PM
Ford79
12-28-2000 08:23 PM
Quick Reply: Stealth intake hitting carb?
