Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-21-2004, 03:11 PM
LittleRedRanger LittleRedRanger is offline
Garage is empty, add now
LittleRedRanger is starting off with a positive reputation.
88 Ranger problems
I have a few things I would like some help with. My Ranger has developed a rod knock. Is this a common thing for the 2.3? What does it take to repair?
Also, my charge light comes on and off on it's own. It does not stop charging, it charges a good 14.4 volts every time I check it.
Again, is this a common problem?
Lastly, it doesn't idle the same all the time. It is either at 900, 1200-1300 or right around 1800. I can't seem to find any reason for this. Any ideas?
Thanks...
  #2 (permalink)
Old 03-21-2004, 07:24 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Rod knock isn't "common" with the 2.3. Some engines live harder lives than others.
As a minimum, you'd have to pull the crank & have it machined down .010. The new bearings would be - .010 to fit.
You may also need to have the big ends of the rods re-sized if they have gone out of round.
The voltage regulator may be on the way out. It may fail soon or, like my work truck, last a long time. It's one of those things that can't be predicted.
Go to the Ranger and B-Series board. The third post there is a "sticky" called "Technical Information". Click on it and scroll down to "Pulling EEC-IV Codes". It would stand to reason that there's a faulty sensor or other part that is causing the irregular idle problem.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
Tags
88, ford, problems, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
