Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 401, 477, and 534 SD Engines
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #76 (permalink)
Old 11-24-2005, 04:51 PM
Louisville Joe is starting off with a positive reputation.
The Fotd GAA tank engine was based on an unsuccessful V-12 aircraft engine Ford was experimenting with. I have heard that it was based on a Rolls-Royce design.
Sponsored Links
To remove this ad, register today!
  #77 (permalink)
Old 11-24-2005, 09:43 PM
GreekGod is starting off with a positive reputation.
1968 Ford industrial engine comparison chart
1968 comparison chart of Ford industrial engines
  #78 (permalink)
Old 11-25-2005, 01:13 AM
"Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE.
Joe, your correct as it was a Neoplan bus maybe 30 passenger. It had a belt drive to a 90 degree gear box that turned the radiator fan on the left side. For what looked like a small motor that thing moved quite well even when full of crap as a storage shed. Thanks for the information.
Just think how a GAA would look and perform in a 68 F250. This would be a step up on the 427 cammer motor.
.....=o&o>.....
__________________
.....=o&o>.....
  #79 (permalink)
Old 12-28-2005, 09:11 PM
karl_ct is starting off with a positive reputation.
I have a 1960 F1000 with this engine so I've heard quite a bit about it from the old timers, I've been told that it came out in 1958, I've also been told that the first 3208 Caterpillar diesels were built on Ford 534 blocks.
  #80 (permalink)
Old 12-28-2005, 09:29 PM
Kruse is starting off with a positive reputation.
Quote:
I think the only similarity between the two is the weight.........
  #81 (permalink)
Old 12-28-2005, 09:34 PM
just what they told me, I won't guarrantee a thing.
Have a good New Year, Karl
  #82 (permalink)
Old 01-06-2006, 02:09 AM
admiralturbo's Avatar
admiralturbo is starting off with a positive reputation.
A 1200 cfm holley and a huge ATI pro charger and some porting/polishing sound good to me
__________________
1988 Ford Bronco Deuce
I've Cut It Three times and It's still too short!!
  #83 (permalink)
Old 01-06-2006, 06:51 PM
Actually, I remember hearing that Ford tried to make a diesel version of it in the mid-60's, but the project ran into trouble. International made a diesel version of their big gas V-8, the DV-550, and G.M.C. had diesel versions of both their gas 478 V-6 and 637 V-8's, the Toro-Flow's. The forerunner of the Cat 3208 was the 1140/1150/1160 V-8's, and those were designed by Cat for Ford (though International and G.M. used them as well).
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
