Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 401, 477, and 534 SD Engines
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #61 (permalink)
Old 04-27-2005, 03:31 PM
Momudder720's Avatar
Momudder720 is starting off with a positive reputation.
490 rpm...i bet that sounds very nice...you oughta get some audio of that so I can put it on repeat and have it put me to sleep.
__________________
02 Ranger 4.0, 5-speed, 4x4 FX4
72 Bronco, 351W, C6, 4.10's, tube buggy
79 Ford with 93 Chevy body, 460, C6
Sponsored Links
To remove this ad, register today!
  #62 (permalink)
Old 05-24-2005, 07:46 PM
bigbird is starting off with a positive reputation.
thanks, any little bit to help refurbish my "new" 72 rollback with a 534. p.s. i'm getting the gas gauge fixed, that puppy DRINKS gas.
  #63 (permalink)
Old 05-24-2005, 10:07 PM
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Well, just go down to Napa and get yourself a rebuild kit, is all I can tell you. You might want to swap it out to another motor, like a custom rebuilt 390. I can help more in the FE forum if you want to go that way.
__________________
Kurt
1970 Ford F100, FE 390
1992 Explorer, 225,000 miles
"Thinking is the hardest work there is, which is the probable reason why so few engage in it." -Henry Ford
  #64 (permalink)
Old 05-26-2005, 01:48 AM
dueceman is starting off with a positive reputation.
Old Super Duty Ford motors
Long time lurker, first time poster. I know this may sound silly , but I have read that lots of folks used the old SD motors to run stationary equipment, ect. Is it possible to use one nowadays to run an electrical generator? Thanks for any replies.
  #65 (permalink)
Old 05-26-2005, 01:15 PM
Well, anything's possible, and I dont see why not. I've heard something about having to run the engine at a constant 3600rpm for 60Hz electricity.
If you're good with a welder, and good at designing stuff, I say go for it.
__________________
Kurt
  #66 (permalink)
Old 07-05-2005, 11:56 PM
yalincoln2 is starting off with a positive reputation.
these engines cam out in 58 and were based on the 430 lincoln engine. plank heads with the combustion chamber in the cylinder. the linc. 430's had 4.9" bore centers, same as the 460's. the 401,477,and 534's had 5.5" bore centers which makes the engine a couple inches longer. they made bellhousings for the standard 5 speed or the 10 speed roadranger. they also made a 10 speed auto, similar to the select-o-speed that was used in farm tractors.
  #67 (permalink)
Old 07-06-2005, 10:23 AM
cfd29's Avatar
cfd29 is starting off with a positive reputation.
I am on my local Fire Dept here and we have two fire trucks with the 534 engines in them, one is a 1970 and the other is 1980 model, both have the 5 speed tranny and both are in the C series cabover truck. They really roar. I have run the trucks at fire scenes pumping for long periods of time at high rpm and you can look into the front wheel well and see the exhaust mainfolds "glowing" bright red, Engine just keeps on with no problems, it is truly a beast
  #68 (permalink)
Old 07-25-2005, 07:00 PM
anyone put electronic ignition, fuel injection or alternative fuels to these beasts? great way to get a little economy from them
  #69 (permalink)
Old 11-23-2005, 02:02 AM
"Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE.
Today I helped a friend get a propane bus running, it's at least 20 years old. He thought it was a 460 but to me seemed larger and had the oil filter sticking out the right side of the block not left like FE's. The front of the motor points to the rear of the bus, had about 8 belts for all the accessories. This bus was 35' long with a 90 degree gearbox to run the radiator fan, a 534? Didn't Ford make a OHC aluminum V8 air cooled motor for tanks in ww II around 840-860 ci?
.....=o&o>.....
__________________
.....=o&o>.....
  #70 (permalink)
Old 11-23-2005, 04:00 PM
The tank engine, I believe, was a shaft-driven OHC 60 degree V-8. Because of the 60 degree configuration, as opposed to the 90 degree, it took up relatively little space, about the same as a 460, width-wise. Now if I could just get my hands on one...I think it was still a cast iron block.
__________________
  #71 (permalink)
Old 11-23-2005, 07:43 PM
GreekGod is starting off with a positive reputation.
Ford's 534 info-posted in gallery?
I think I posted the Ford literature on the 534 in the "Galleries" but darned if I know how to find or view it!
  #72 (permalink)
Old 11-24-2005, 12:00 AM
Click on my name and...
Quote:
...Now I figured it out! Click on my name (GreekGod) and then click on "View Gallery"...You can view the original Ford spec info on the 534...I probably should have left it original size.
  #73 (permalink)
Old 11-24-2005, 12:07 AM
I was wrong. The Ford GAA is the monstrous engine from WW2 tanks, and it was indeed a 1 piece casting of aluminum. More info here...
http://www.bacomatic.org/~dw/yore/gaa.htm
__________________
  #74 (permalink)
Old 11-24-2005, 04:26 AM
Momudder720, many thanks for your pictures of the GAA engine. I recall back in the late 60's a friend of dad's had a tank that he used to drive thru houses for demolition. The tank was eventually scrapped but he kept the motor, it had a broken rod. He died and the motor vanished in the 80's, I wanted it but was too late.
.....=o&o>.....
__________________
.....=o&o>.....
  #75 (permalink)
Old 11-24-2005, 04:49 PM
Louisville Joe is starting off with a positive reputation.
About that bus: was it by any chance a Gillig? Gillig made some transit buses in conjunction with Neoplan with propane-fueled 477 Super-Duty V-8's in 1977. Kind of sounds like what you have there. And, to top it off, some were used in Santa Clara.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
