Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 03-20-2004, 07:44 PM
SamD SamD is offline
SamD is starting off with a positive reputation.
Pros and Cons on electric fuel pump
Anyone have an opinion on replacing the fuel pump on my '41 with an electric one? My 6 volt pump needs to be replaced and I was wondering if an electric one would be a wiser choice, and are they easy to install?
  #2 (permalink)
Old 03-21-2004, 01:18 PM
46fordtruck's Avatar
46fordtruck 46fordtruck is offline
46fordtruck has a good reputation on FTE. 46fordtruck has a good reputation on FTE.
Installing an elc fuel pump is pretty easy. Most important thing is to mount correctly, and that the output of the pump is not too high for the carb. You can buy a regualator if you need to lower pressure. Most elec fuel pumps need to be mounted lower than fuel tank. The fuel lines to connect to the FP will be no problem, just have to make up a couple of new lines. I have been running an elctric pump on my '70 Mustang for years, with no problems. It's really a personal choice, the mechanical pump is good, especially if you're engine is stock, but the elec is also good. Of course, staying with the mech pump will be less work, and have your truck back on the road faster.
__________________
Gary-
'46 Ford 1/2 ton
Tags
46 , cons , electric , ford , fuel , installing , pros , pump , pumps , truck , volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
