Flathead V-8 parts identification
Old 03-17-2004, 12:12 PM
51dueller's Avatar
51dueller
51dueller is offline
I was just wondering about some flathead parts I have. I have 2 different late 49-53 timing covers. Both are aluminum. One is more compact and rounded while the other has the centre a really big circle and more like sharp edges. That one doesn't have any part numbers on it. I also have 2 49-53 intake manifolds. One of them has been stamped 2 and has a plug under the vacumn port while the other is stamped 1 and doesn't have a plug. I'll have pictures posted later on. I'm just interested in what years they were used and models.
Old 03-17-2004, 05:03 PM
51dueller's Avatar
51dueller
I got the pictures up.
Old 03-19-2004, 12:17 PM
51dueller's Avatar
51dueller
The pictures are in my gallery.
Old 03-21-2004, 04:50 PM
mtflat's Avatar
mtflat
mtflat is offline
Nathan,
Re: timing covers - The smooth cover is typical Ford/Merc for the later dist with a longer shaft. The cover has a support hole for the extra shank length to fit into. The 'green' cover with the sharp edges, I'd guess is aftermarket??? ...... or Ford was really dipping into the bottom of the barrel for parts toward the end of the run. It too is for a later distributor - you can see the indent where the collar is for the longer shaft.
Re" intakes - they're the same, just different, right? I have one of the 'plugged' intakes that came off a 52/53 EAB engine. I replaced the plug with a nipple and use that port for my pcv hose. I think it's typical of larger truck intakes that needed additional ports for vac - brakes, etc. The other was likely pickup/car intake of the same vintage.
Old 03-21-2004, 05:59 PM
51dueller's Avatar
51dueller
Thanks for the info. I guess I have a rare timing cover. That timing cover came off a '51 engine with EAB heads and adjustable lifters that was put in a '46 Ford 2 ton. I think I'll use the truck manifold if I ever need another vacumn port later on.
Old 03-21-2004, 06:07 PM
51dueller's Avatar
51dueller
Looking at the timing covers I think that unknown one's timing pointer is lower than the ford one. Did ford use a different crank pulley for the flathead? The pulley that was on it is the same as my other one.
Old 03-21-2004, 10:01 PM
mtflat's Avatar
mtflat
mtflat is offline
I noticed that pointer difference - forgot to mention it. Cars used a smaller pulley than trucks, and had narrow belts.
77 pickup
41
07-20-2021 06:23 PM
tony1947
04-04-2010 11:41 PM
restoringmy46
Flathead V8 & Flathead 6
12-16-2004 10:23 PM
frank_1
09-11-1999 06:09 PM
Quick Reply: Flathead V-8 parts identification
