85 F-250 rims on 70 F-250?
As long as you're using a conical lug nut (on a rim designed for conical nuts) they should seat and center the rim even if the holes are a *little* big. If the wheels are for shank-style (mag wheel) lug nuts, you need to make sure the shank size is right for the wheel.
How do you tell the difference between shank style and conical lugs? The aluminum rims have lugs that are about as long as the studs and are open on one end and tapered to center the wheel and closed on the other. The lugs on my 70 have tapered ends to center the wheel also but are open on both ends(looks like a nut).
lt dan
01-25-2019 01:08 PM
bignewf
04-21-2016 12:31 PM
lt dan
05-25-2001 12:43 PM
