Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-18-2004, 10:24 PM
kitsapcountychopper is starting off with a positive reputation.
89 trans zf 5 change to 6 spd
anyone done a zf 5 spd change over to a six spd ?? 89 7.3 .i have a low geared tow truck and it whines up way to hard at freeway speeds
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-19-2004, 12:04 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
The 6 speed will not get you much extra.
The final drive ratio in the 5 speed is .76
The final drive ratio in the 6 speed is .72
With 32 inch tires that works out to about 5 MPH at 3000 RPM
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
Old 03-24-2004, 04:06 PM
wycowboy's Avatar
wycowboy is starting off with a positive reputation.
How do you like your 89??
I'm looking at buying one any problems
__________________
97 F250 PSD, sc, 4x4 5sp, 3.55. 150K miles, 6637, Amsoil 5-40w/ bypass, SCTM, auto meter, Napa Coolant fliter. 203*t-stat,
  #4 (permalink)
Old 03-24-2004, 04:21 PM
89 superdutys are strong trucks.4 wheel disc brakes work well .
  #5 (permalink)
Old 03-24-2004, 04:35 PM
wycowboy's Avatar
Are there any problems I should look out for . Is the 89 7.3 a good power plant?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
