Blowing sound/ unstable idle - Ford Truck Enthusiasts Forums
Old 03-18-2004, 03:03 PM
Jack DK Jack DK is offline
Jack DK is starting off with a positive reputation.
Question Blowing sound/ unstable idle
Have resently got a F250 year 2000 Engine: Powerstroke 7,3 diesel.
When the engine is started a blowing sound is coming from the exhaust periodically. When you starts to drive at low speed the engine is throttled also periodically and the sound is heard again.
It is very irritating
When the engine reach its normal operation temperature the problem disappeares.
I can see a linkage in the turbo outlet is moving. I believe it must be some kind of a waste gate. But why is it acting like that.
Do someone have a solution to solve this.
What is wrong? and what can be done.
Thank you in advance for any help and advice.
Best regards I.Thomsen
Old 03-18-2004, 03:07 PM
mjwhip2 mjwhip2 is offline
mjwhip2 is starting off with a positive reputation.
Sounds a lot like the ebpv. Helps your truck warm up, completely normal. Can always disconnect.
Mike
Old 03-18-2004, 03:10 PM
strangmk strangmk is offline
strangmk is starting off with a positive reputation.
From what I have read here, it sounds like your EBPV Exhaust Back Pressure Valve. It is supposed to close when the engine is cold to warm up the truck faster. I unplugged mine.
Old 03-18-2004, 03:11 PM
search this forum for ebpv. You'll get all the information you would ever want or need concerning this.
Mike
Old 03-19-2004, 01:01 AM
Thumbs up Disconnecting EBPV device
Thank you very much for your advice so far.
In which way is it best to disconnect this EBPV device.??
By mechanical blocking or removing the linkage, or jumping some electrical sensor. ?
I believe there must be some kind of device sencing the temperature of the engine.
Do disconnecting the EBPV not have any negative influence, except for longer warm up periode.
Of cause you must go easy with the engine until it has the prober temperature.
I wonder why Ford have made this solution for warm up.
Brgds I. Thomsen
Old 03-19-2004, 06:11 AM
Disconnected EBPV
I have now disconnected the plug to the sensor on the turbo charger. Now the engine behaves normal also in cold condition.
Thank you again to this great forum and the people who helped me.
Best Regards I. Thomsen
Blend Door or Something Else? rexpedition99 1997-2006 Expedition & Navigator 20 08-24-2012 12:40 PM
When in gear engine sputters virgojeep 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-11-2009 06:27 PM
1995 Ranger wont start after short drive? The Duke Ranger & B-Series 4 12-16-2008 01:06 PM
Break In period - Mods Question SDTruckMan 2004 - 2008 F150 1 05-10-2007 12:10 AM
Cold start blow-off valve 97F350PowerStroke 1994.5 - 1997 7.3L Power Stroke Diesel 5 01-29-2007 09:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
