Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 03-17-2004, 11:18 AM
gburkett gburkett is offline
Garage is empty, add now
gburkett is starting off with a positive reputation.
MAP sensor
Cab anyone tell about what the map sensor is for and where it's located? I'm wondering if it has anything to do with fuel milage?
  #2 (permalink)
Old 03-17-2004, 11:32 AM
jpsartre12 jpsartre12 is offline
jpsartre12 is starting off with a positive reputation.
A MAP sensor measures the Manifold Absolute Pressure (hence MAP) and is a means of determining an engine's load condition.
A high vacuum is a low manifold absolute pressure. The two are inversely related, so under high load, you have a low vacuum and high manifold absolute pressure. It is normally found after an engine's throttle body, just before or on the intake manifold. I don't know where it's specifically located on the 7.3L.
__________________
Bumper sticker of the year:
"If you can read this, thank a teacher....and since it's in English, thank a soldier
1991 Club Wagon XLT - Tow Vehicle
  #3 (permalink)
Old 03-17-2004, 11:48 AM
JMorton JMorton is offline
JMorton is starting off with a positive reputation.
It is located on the passenger side of the firewall, on the heater case. There is a vacuum line on the turbo y-pipe, follow this line towards the heater case and it ends at the MAP sensor.
__________________
97 Crewcab PSD, Wildman chip, DIY-injectors stage 1's, SD Intercooler, 3" DP, 4" straight pipe, DIY exhaust brake, Tymar, Shimmed FPR, Bully Dog propane, Diesel Turbo Lifesaver, Autometer Gauges, B&W hitch, Timbren SES.
  #4 (permalink)
Old 03-17-2004, 12:32 PM
Thanks guys, I appreciate the reply. How much does it have to do with the fuel milage?
  #5 (permalink)
Old 03-17-2004, 02:12 PM
Quote:
The short answer is "lots". MAP output is fed into the PCM which controls the fuel injectors. False readings can lead to either lean or overly rich conditions.
__________________
  #6 (permalink)
Old 03-17-2004, 10:22 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud of
f250juggernaut
A couple of diesel specific points that I think are applicable to this thread.
1. There is no throttle body.
2. There is no vaccuum, only pressure.
3. Diesels always run lean.
On the PSD the MAP sensors basic function is to measure the engine load via the amount of boost being produced and send that info to the PCM so that it can adjust the fuel curve accordingly. It's possible that a "slightly bad" MAP sensor could affect the milage, but I would think there would be other, more severe symptoms associated with it. Bad idle, poor running, lack of power, check engine light....that sort of thing.
__________________
Scott - FTE moderator
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
  #7 (permalink)
Old 03-18-2004, 07:37 PM
Would an air leak in the line also cause the milage to go down? meybe I'm crazy or just don't know what it's suppose to sound like but the engine sounds like it's getting air in the line to the injectors. is there a way to tell if you have an air leak in the fuel lines? I appreciate the help from everyone, makes this forum great!
  #8 (permalink)
Old 03-18-2004, 08:17 PM
Stroker01 Stroker01 is offline
Stroker01 is starting off with a positive reputation.
If your getting air in the line to the injectors, you'd be able to tell cause your exaust would be white and smokey. If it sounds like an air leak just after a cold startup and goes away, that is normal.
__________________
2001 F250SD PSD CC 2x4
K&N More to come
  #9 (permalink)
Old 03-18-2004, 08:22 PM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
What year is the truck? If it's a Superduty with a stock fuel system then it is very likely that the fuel system is drawing air.
Do a search for "tank mods" and "pre-pump mod" and let us know if the descriptions found there in are similar to your situation.
How poor is the milage that spawned the thread?
__________________
  #10 (permalink)
Old 03-20-2004, 02:48 PM
Cookie, I have a 01 crew, 4x4. I have done the fuel tank mods and put the inline filter on and changed the clamps like the mod says to. When I bought the truck I was getting about 16mpg. Now I can't get better than 13.5mpg. I have the stinger w/chip and a 203 thermostat so I thought I would be getting better than this! The sounds isn't a hiss or anything.....just sounds like it's missing at low speeds. to me it sounds like it would if there was air in the line but I have no smoke out the exhaust either. I did talk to the dealer once and was told that this was normal milage but I have seen to many others to know that this isn't true. Oh, by the way, I do drive conservately (most of the time).
  #11 (permalink)
Old 03-20-2004, 03:40 PM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
Is it still cold in Idaho? Might just be winter fuel. Mine got low 15's for the last couple months, but with the return of summer fuel down south it's back to the mid 17's the last 2+ tanks.
__________________
Tags
1997, 2006, 73, diesel, ford, intercooler, located, location, manifold, map, mod, powerstroke, sensor, symptoms, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
