Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-16-2004, 01:23 PM
Where yat is starting off with a positive reputation.
Rear End Fluid Change When Towing
Recently read at an RV Forum that up until some uncertain model year, you needed to change the rear end fluid if you were going to be towing. This supposedly applied even with factory towing package. I had never heard of this before and would appreciate some insight into this situation.
__________________
Dean
SE Louisiana
00 Expy 5.4
99 Crown Vic
96 Contour 5-speed
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-16-2004, 01:35 PM
MisterCMK's Avatar
MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold
That's BS. I tow 5 to 6k per year, and haven't changed my rear end fluid. If you have the towing package, all you have to do is hook up the trailer and go.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
Quote:
Originally Posted by tcbofade
I have no brain
  #3 (permalink)
Old 03-16-2004, 01:48 PM
tsdrallyer is starting off with a positive reputation.
If youi were using dyno lube yes, it's a good idea to change every 30K miles or so, depending on load and use. However, Expys with tow package come with syn oil and don't need to be changed under normal use. Maybe every 50K miles of hard use. My '97 came with lifetime syn oil in the LSD and towing package. It's given no trouble from front or rear and I"ve towed up to 7500lbs with it for a total of almost 90K miles.
__________________
'08 EB,5.4L,4x4,3.73,17" wheels,rear air,HDtow pkg. all options except convenience pkg.
'05 Escape Limited, 4x4, all options, tow pkg.
  #4 (permalink)
Old 03-16-2004, 06:03 PM
buzzard's Avatar
buzzard is starting off with a positive reputation.
I'm pretty sure "ALL" Expys come with same synthetic fluid whether they have tow package or not. The LS models have an additional additive to reduce friction.
__________________
Jim
1968 F250 CS, 390
Pebble Beige/Wimbledon White
2000 4x4 Expedition, 5.4L
White
  #5 (permalink)
Old 03-16-2004, 07:32 PM
khmorse is starting off with a positive reputation.
I believe I saw that thread also talking about the differential. I think they were talking about older trucks/SUV's that did not come w/synthetic lube like they do today. The recommendation was to remove the dino and put in synthetic. Most new trucks, especially if they come w/a tow pkg, will already have synthetic diff lube.
__________________
Ken
'04 F350 Lariat, CC, 6.0 PSD, short box, FX4, w/camper pkg
'03 Palomino 21SDSL hybrid TT
  #6 (permalink)
Old 03-17-2004, 08:36 AM
Thanks very much!
__________________
Dean
SE Louisiana
00 Expy 5.4
99 Crown Vic
96 Contour 5-speed
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
