stupid blonde needs help 1984 where's oil cap?
Ok, I realize that the people that post on here are generally knowledgable about their vehicals, however I'm desperate. I now own a 1984 ford f150 which used to belong to my brother, its a tank, anyways, I'm also very stupid about vehicals and the owners manual has long since been lost and you can't find one on the internet. So my question is, where the heck do you put the oil in. I found the cap for power-stearing, and I found the dipstick, both for the oil and transmission fluid, but I'm confused as to where you put the oil in in the sucker! Please help
Coming from the air filter (the round thing on top of the ingine, There is probably a rubber hose that leads to a crank case breather (round mettle thing about the size of your fist.) It is attached to the valve cover (a long box shaped thing bolted to the top of your engine.) That breather will unscrew and you poor the oil in there. If there is no hose, hust look for the valve cover and there will be somthing on there that will unscrew to get into the valve cover so you can poor in the oil.
laurnil...if you have a 300 straight six (six cylinders in a straight line, front to back) the oil fill cap is right at the front of the valve cover...it unscrews just like 82Step explained...the 300-6 only takes about 6 quarts to fill from bottom to top, and if you're way low on oil, once you get oil on the dip stick, it generally takes 2 more quarts to top it off...you don't want to overfill your oil, tho...
another idea...take the truck in to an auto parts store, and have one of the parts counter people show you where various fluid fill holes are...
MontanaFord
MontanaFord
Originally posted by bremen242
here is a pic of my '85 oil filter cap. '84 is the same, but the breather tube goes into the top of the oil cap. Note: if your cap looks like mine, it will probably be _very_ tight, because it seems to tighten up. Don't know why.. The 84 just takes a half turn to take it off.
82: On my '84, the wires were in good, and weren't falling out of the looom. Of course, my father and I had owned it since '85. I think people just screw with them because they don't know what they are doing. If I keep this truck, I'm pulling everything off and redoing all the vacuum lines and fixed all the wires. But that is after my f250s done.
lol
hey i was lookin at my engine just 4 kick (very bored) and i noticed quite a few bolts blockin some hoses. anyway, my starter just died and i have to replace it tues 9just ordereed parts today) thank god i dont have to jack it up and i can work on my beast in the slippery rock university parkin lot lol. sorry i just need to vent. its very flustering. have fun, and be good.
mike
mike
