Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-15-2004, 11:09 PM
Rcmgiasson is starting off with a positive reputation.
4.6 head options
i have a 97 f150 4X4 with a 4.6 with 50 thousand miles on it. unfrotunately it has blown the head gasket on the passenger side and is leaking oil onto the exhaust. I heard that these paticular heads are prone to this type of blow out. what are my options. ford wants $2100 to do both gaskets, but what is the chances it won't happen again. for $2100 is there other heads i could upgrade to that would substantially improve power. perhaps off a mustang or a mark VIII. will these heads bolt on, will the intake match up or will the mustang/lincoln intake need to be used and finally will the computer function properly. how about aftermarket heads. i've looked around, but so far all i can find is mustang heads. will these mustang heads work or do they require modification. If i'm going to spend $2100 on engine work i want some performance and not headgaskets that will end up leaking again. thanks
__________________
mike g
08 f350 lariat 4x4 Diesel
89 f150
95 f150(now wrecked)
97 f150(sold)
67caddy
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-15-2004, 11:28 PM
krunker is starting off with a positive reputation.
If you want to replace both heads I would go with the updated PI heads. Course if you do that you will need the intake too. Plus I think Comp makes a new cam for these heads that you can throw in. Not sure how much you want to spend on this. Check out this link for the heads - http://www.performanceparts.ford.com...tKeyField=6124 These are preassembled with mustang GT valve train and cams, not sure if this is similar to truck engine. There is another site where I found the head without the cam and valve train installed but I can't remember where. Might want to call and see if this will work if you plan to order.
__________________
1997 F150 4X4 4.6 Std.
List Mod's in Gallery
FTE
  #3 (permalink)
Old 03-16-2004, 10:16 AM
what year did the updated PI heads come out. what are the heads called on my engine. Will the PI heads give much performance. thanks.
__________________
mike g
89 f150
97 f150(sold)
67caddy
  #4 (permalink)
Old 03-18-2004, 01:21 AM
The PI heads came out in 99 or 2000. Can't remember which. If I remember correct you get between 20 and 25 horses. Maybe more. You probably have the Romeo heads (named after the plant they were produced at).
__________________
FTE
  #5 (permalink)
Old 03-18-2004, 03:48 PM
JustinH's Avatar
JustinH is starting off with a positive reputation.
Here is what I recommend for your 97. Assuming you can do the work yourself, you can do the job rather reasonably.
Get your non-PI heads fully ported, with a five angle valve job. Two shops that do excellent work off the top of my head are fox-lake and Renegade Racing.
Have them install PI cams into your non PI heads.
Install a PI intake on your new ported non-PI heads.
With this combo you will make more power than ported PI heads, and you will retain the stock compression level.
If you put PI heads on a NPI motor, then you will bump your compression level up.
It is very possible to make 300hp at the wheels N/A with a 4.6 mod motor. The combo I have seen make 300+ HP was a built shortblock, fully ported SVO heads, with a ported and port matched Bullitt intake, and custom ground cams.
JH
  #6 (permalink)
Old 03-18-2004, 09:26 PM
LxMan1's Avatar
LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold
The PI heads are the same on a truck and Mustang. Same valves, cams ETC. HotRod mag put a 5.4L in a 99 GT out of a van awhile back and checked the heads. They were identical.
Non-PI heads are probably the same way.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #7 (permalink)
Old 03-19-2004, 10:44 PM
problmsolver is starting off with a positive reputation.
this i am not totally sure about, but i think the pi heads are only for the 5.4l . i would just replace the head gasket on the passenger side and not worry about the other. the reason is the passenger side oil feed is and the back of the head and when it leaks it runs down the head to block matiing surface and drips directly of the rear of the exhaust manifold. the left head (or drivers) has it's feed galley at the front of the head, behind the front timing chain cover where it never creates a problem leaking externally. NOW do these leaks every get bad enough to creat oil problems??? i have never seen one go past a annoying smell. i would not waste the time of money doing the left headgasket, unless u want to try some performance ideas. ford has inproved their headgaskets for these modular engines, USE FORD HEADGASKETS!!!)
__________________
Ford Tech.
  #8 (permalink)
Old 03-20-2004, 08:10 AM
JustinH's Avatar
Quote:
No sorry thats wrong.
  #9 (permalink)
Old 03-20-2004, 04:45 PM
heads
thats why at the beginning of my post it says, " this i am not totally sure". the only time i have run into a pi head was working on a 5.4l there was a tsb about not swopping pi heads for non pi heads, that was the first i had heard there being any difference.
__________________
Ford Tech.
  #10 (permalink)
Old 03-20-2004, 05:32 PM
okay help me out and tell me if this is going to work or if i'm better off with the other ideas mentioned above. I have found a set of Mark VIII 4.6 32 valve heads new and complete for $495. If i were to use these heads who much would it raise the compression and what would i all need, would i need a different intake, timing chain cover ect. And how about the computer. will it still function properly or would need to be changed too.
Justin H, do know an approximate cost to do such modifications to my non pi heads or possibly a site address where i could find this out.
Thanks alot for everyones input, with out you guys i might end up with something that won't work.
__________________
mike g
89 f150
97 f150(sold)
67caddy
  #11 (permalink)
Old 03-20-2004, 06:06 PM
LxMan1's Avatar
New wiring harness would be required too anlong with a proper PCM, etc!!! You would need a PCM that is compatible with your vehicle and the modified engine.
Possibly one from a 32V Navigator might work. Not sure though.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #12 (permalink)
Old 03-20-2004, 07:40 PM
JustinH's Avatar
Here is teh address for fox lake.
http://foxlake.accrisoft.com/index.p...e6eaad3b7ef137
  #13 (permalink)
Old 03-20-2004, 11:09 PM
good luck putting 32 valve heads in place of 16 valve heads, different chain, maybe different front cover, different timming chain guides and tensioners, i would say different intake, change pcm. if those are good heads though they seem cheap, may want to buy them and put them on ebay. a new 4.6 head has got to run double that with out valves. good luck with your project
__________________
Ford Tech.
  #14 (permalink)
Old 03-21-2004, 12:54 PM
Okay, the 32 valve heads seem out of the question as i don't want to change that many components. looks like i'm going to stay with the old heads if i can get them to seal properly.
Psolver do know of the part # for the updated ford gasket and for the old gasket. I talked to the parts guy at the local ford dealer and he hasn't clue what i'm talking about.
justinH, will the PI intake directly interchange with my old intake or will other stuff need to be changed too.
thanks
__________________
mike g
89 f150
97 f150(sold)
67caddy
  #15 (permalink)
Old 03-21-2004, 01:15 PM
let me see if i can get into ford oasis from my home computer.
__________________
Ford Tech.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
