Code 122 - TPS faulty or need of adjustment?
03-15-2004, 09:56 PM
on
Hi 3.0L gurus.
I'm getting a code 122 from the ecu of a 3.0L Vulcan in an Aerostar.
Does this mean the TPS is dying, or is a simple adjustment needed?
Thanks.
03-16-2004, 06:01 AM
DTC 122 indicates the Throttle Position (TP) sensor signal is less than the Self-Test minimum value.
Possible causes:
-- TP sensor may not be seated properly (tightened down).
-- Damaged TP sensor.
-- Open harness.
-- Grounded harness.
-- Damaged Powertrain Control Module (PCM).
pross
06-03-2021 07:25 AM
LSO1123
12-22-2015 01:29 AM
Gene Duval
10-01-2015 08:38 AM
njtinman2
09-11-2014 08:22 AM
sdgrant150
07-10-2001 06:47 PM
122 ,
30l ,
40l ,
adjustment ,
code ,
dtc ,
ford ,
obd ,
position ,
sensor ,
t0 ,
throttle ,
tps ,
trouble ,
troubleshooting
