03-16-2004, 09:14 PM
Apparently I need to clarify. I did not take the pump off carelessly so I could damage the pump lines and anything else I wished to hit with a hammer then write in to the forum and ask people to lecture me on should haves.
bilder12,
I removed the pump through the back of the housing while leaving the housing attached and the gear timed. I put the key way to the top of the gear. I then removeed the 3 bolts, disconected the lines and remove the 3 nuts that secure the pump to the housing. I would like to confirm that the gear is on correctly before I crank the engine over or cause damage. Currently the pump shaft is recessed into the gear about 1/8". Does anyone have a picture of this or now if it is correct.
Thanks,
Gavin
