Any other 534 owners?
Old 06-12-2007, 09:11 PM
jlgreen8's Avatar
jlgreen8
jlgreen8 is offline
I am looking for the cylinder arrangement (numbering). The left bank is further forward than the right bank. The cylinder arrangement must be unique.
Where is #1 and #2 and so on?
While you're there what is the valve lash?
  #77
Old 06-12-2007, 09:19 PM
magila's Avatar
magila
magila is offline
point gap .017 plug gap .030 firing 15486372 10 btdc int .020 exh same hot or cold according to the book dwell 26 - 31 right bank 1234 left 5678 front to rear hope that helps you
  #78
Old 06-13-2007, 12:07 AM
jlgreen8's Avatar
jlgreen8
jlgreen8 is offline
Thanks Magila, although that's not what I was wanting to hear. All this popping back through the intake & exhaust must be related to the carb dumping fuel all over the place. Unless there is some cross fire. The cap looked good and the wires are not bad.
It is firing on open valves. Compression sounds good when cranking .... I'll do the carb 1st then relook at it. Thanks again.
  #79
Old 06-13-2007, 09:50 AM
magila's Avatar
magila
magila is offline
take the advance hose off see if that stops it mine was doing that when i got it
  #80
Old 06-13-2007, 10:11 PM
jlgreen8's Avatar
jlgreen8
jlgreen8 is offline
Thanks magila, the advance hass a solid steel tube, but I can drop it just for grins. When I was looking at the points, they seemed to be within 5 or 10 degrees of the timing mark. But then I was just eyballing it. Of course dynamic timing is always better. I'll try moving the distributor to see what that gets me. I was really thinking I was cross wired. Now I'll do some deep diagnostics to come up with a good fix.
  #81
Old 06-13-2007, 11:28 PM
magila's Avatar
magila
magila is offline
thats what worked for me mine was poping threw the carb everytime reved up or under load idles was great though i set mine at 10 dynamic with no vacuum advance
  #82
Old 06-13-2007, 11:32 PM
magila's Avatar
magila
magila is offline
so i was reading some of the posts do you have a edelbrock carb on that motor if so throw in garbage BIG PIEACE OF JUNK ON THE 534 MINE HAD ONE CAUSED ALL SYMPTOMS OF POPING AND ****Y RUNNING have a 650 double pumper on there now runs great up to 10,000 pounds in it haven't fill higher yet
  #83
Old 06-14-2007, 09:45 AM
magila's Avatar
magila
magila is offline
ignore my last post
  #84
Old 11-08-2007, 10:11 PM
LACitydriver's Avatar
LACitydriver
LACitydriver is offline
534 owner
I have a 1967 Custom Coach Landcruiser motorhome that looks just like a Flxible bus. It has a 534 in the back that is mated to an Allison MT42 6 speed transmission. The fuel tank holds 150 gallons.
  #85
Old 11-09-2007, 11:58 AM
ms_michelle's Avatar
ms_michelle
ms_michelle is offline
Pictures, we need pictures of your motor home. Some of the engine compartment too.
Michelle
  #86
Old 12-16-2007, 11:40 AM
dugyver's Avatar
dugyver
dugyver is offline
Dugyver
We have a 78 L-series with a 534 engine. It powers a Failing water well drilling rig. This thing is a mechanical marvel! It has more transmissions and gearboxes than you've ever seen. You learn to make a lot parts yourself though. Not alot of parts available for this old of a piece of equipment. Kinda like a Timex, just keeps on ticking!
  #87
Old 01-06-2008, 07:02 AM
q240z's Avatar
q240z
q240z is offline
I just posted to the classifieds two 534TTi engines (yes, that's twin turbo and intercooled) that were marinized by SeaMaster back in the '60 and '70s. They just came out of a yacht that's been sitting on land for 18 years. I don't know if the engines are rebuildable or not, but the spare parts you could pull off of these two ought to be useful. The turbo manifolding, plenums, and intercooler housings would cost a bloody fortune to have cast these days.
Cheers,
  #88
Old 04-21-2008, 03:58 AM
mokehill151's Avatar
mokehill151
mokehill151 is offline
Hello. New to here. I have a 67 Ford C950 Van Pelt Fire Truck with a 534 and it runs good and the truck looks great. Got it because the Fire Dept had a hard time getting it to run good and got tired of shifting a manual. Drove it home 450 miles and went through 9 quarts of oil and finally went through the carb and found out who ever went through it the last time put the jets in backwards! Secondarys in the primary holes. Needless to say it does not burn that much oil any more and runs pretty good for an old beast. Best milage 5.5 and worst going up hill, 2. Will try to post photos of it.
  #89
Old 04-26-2008, 01:23 AM
fire534's Avatar
fire534
fire534 is offline
I have a 63 c1000 Towers firetruck with a 55' snorkel lift and a 534 motor. Had trouble with the carb, had it rebuilt once and still have trouble with it. I am looking at doing a throttle body injection conversion. Anybody out there ever do this with a 534?Also looking for a manual for the 534 if anyone knows where i can get one - looked all over and no joy.
  #90
Old 12-21-2008, 05:45 PM
Econoline 150's Avatar
Econoline 150
Econoline 150 is offline
Trucking company I worked for had a few cabover Fords with the 534s, they were serious gashogs, after the '73 gas crunch they got rid of them and replaced them with diesels. I remember the biggest issue is drivers would overrev the snot of of them and they ended up blowing the engine if I remember correctly.
Quick Reply: Any other 534 owners?
