Any other 534 owners? - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 10-18-2006, 08:42 PM
blackford85 blackford85 is offline
blackford85 is starting off with a positive reputation.
Yea i have one i swapped into my 91' f-350 over the summer. If u go to personal announcements u can read all about how i swapped that motor into my 91' dually. Let me tell you the powerband is beautiful for my seasonal sled pulling
  #62
Old 10-29-2006, 02:49 PM
adharvey2 adharvey2 is offline
adharvey2 is starting off with a positive reputation.
Quote:
Originally Posted by WPD388
We Have A Fire Truck With A Rebuilt 534. The Problem Is We Can't Find Any Info To Set The Timing On This Engine. Can Anyone Help. we need this unit online asap.
I'm going to the library in a couple days to look up some 292 info. I'll jot down the 534 tune up specs if that would help.
Andrew
  #63
Old 10-30-2006, 11:12 AM
Still in the 60's Still in the 60's is offline
Still in the 60's is starting off with a positive reputation.
My info from 62 is this-
Centrifugal advance dist- 8 degrees BTDC
Dual advance dist- @10"mercury, 5.5 to 8.5 degrees BTDC
points- .014-.016
plugs Champion F10, .028-.032 gap
Hope this helps.
  #64
Old 05-01-2007, 11:19 AM
royster royster is offline
royster is starting off with a positive reputation.
My brother use to drive 534 powered Ford trucks, F1000 models with dump trailers. He said that they could haul heavier loads than any other gas powered trucks and even outpowered most diesels. 300-400 thousand miles on them before any major work was not unusual. He said that another truck company bought a GMC 702 cu in V12 , and it was an equal to the 534 in power but it's gas mileage was much worse.
  #65
Old 05-01-2007, 10:23 PM
Louisville Joe Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.Louisville Joe is gaining momentum as a positive member of FTE.
I don't know that I would say the 534 was the equal of the 702 power-wise. The GMC 702 'Twin Six' was something of a legend in its day. I knew a guy that was a mechanic for a trucking company that ran them back when. He said they would run away from everything, gas or diesel, by a wide margin. No doubt the 534 was a powerhouse, but they never made close to the 300 h.p./600 ft. lbs. of torque the 702 did. Those were big numbers in the early 60's. Most the Minuteman mobile missile launchers were powered by 702's, right up into the 90's.
  #66
Old 05-03-2007, 03:21 PM
Interesting comments about the GMC 702's. My brother said that they were powerful, but they couldn't run away from everything, and he could beat them on many hills carrying the same load. Maybe his Ford f1000 was geared more effectively. The v12's were rated at 275 horsepower and 585 ft lbs of torque. The 534 in its initial offering had 277 horsepower and 495 ft lbs of torque. Also, gas mileage was much better with the 534.
  #67
Old 05-05-2007, 11:04 PM
tgbankst tgbankst is offline
tgbankst is starting off with a positive reputation.
63 c-950 w/477
I have just put an old rollback bed on a 950 and it is really a unique truck. It is an oldie but i love .don't see many of these old trucks anymore.
  #68
Old 05-06-2007, 06:24 PM
ms_michelle's Avatar
ms_michelle ms_michelle is offline
ms_michelle has a great reputation on FTE.ms_michelle has a great reputation on FTE.ms_michelle has a great reputation on FTE.ms_michelle has a great reputation on FTE.
Quote:
We need some pictures. What year 950?
Michelle
  #69
Old 05-08-2007, 09:08 PM
950
Michelle,
The old gal needs some paint but shes special to me because about 25 years ago a friend of mines father restored the truck and i remember it like it was yesterday. The truck has been sitting all of these years and i consider myself a rescuer of sorts. Oh yeah, the truck is a 63 and was all original until i put a Edelbrock carburator on it because the original Holley was flooding the plugs.
  #70
Old 05-08-2007, 09:18 PM
Go to my gallery and check out my big trucks. I love the big Ford trucks.
  #71
Old 05-08-2007, 09:27 PM
950
I checked your trucks out and i do like. The same man i got my truck from has a N series he bought new in mid 60's. It has a 391 and was twin screw and two stick trans. It now is single axle and 5 speed. He used to pull a log trailer with it and now in his retirement uses it as a flatbed to haul hay. He also has a Lousiville cab gas burner that he also uses as a flatbed to haul hay. I sawed up a white oak tree for him and he used the lumber to build a wood bed for the truck. He is in his 70's and can build or rebuild anything. A truly gifted person.
  #72
Old 05-27-2007, 03:58 PM
magila magila is offline
magila is starting off with a positive reputation.
i have a 70 f-900 dump with a 534 in bought it for 1000 buck did some carb and distributor work to it runs like a charm need to do a little external work and will be on my way does anyone know where to find some motor parts for the 534
nice to meet you all
  #73
Old 05-28-2007, 02:44 PM
I don't know what you need but I recently bought a slave cylinder kit off ebay for a very small amount.
  #74
Old 06-12-2007, 12:52 AM
jlgreen8 jlgreen8 is offline
jlgreen8 is starting off with a positive reputation.
534 shootin ducks
Well, I'm not really "the owner" since the 1969 F850 Super Duty actually belongs to the Superior Fire Department, but I get to work on it and they supply the gas to drive it. It is retired Fire Engine #4. Purchased new in 1970.
I runs really bad, no brakes, leaks fuel from the accelerator pump diaphram all over the manifold. The dizzy has been rewired 15426378 so it pops through the carb and the exhaust alot and hits on what ... about 6 or 4? I used a temp gun to see which were firing, not many.
The brakes were out juice, but even after filling and bleeding it would like some more vacuum to do a proper stop.
I've been looking online for some correct information on the engine numbering and firing order for the 534. The firing order is cast into the intake under the carb so that's easy, and it is not the same as all other Ford engines that I have known. Also the left bank is further forward which would tend to make one believe that the cylinder arrangement is unique also. When someone tells you to look at the numbering sequence cast into the intake, they are not talking about a 534. It just ain't there, and there are no "runners" like on an FE. The runners are in the head, not the manifold.
I read a lot of tune up specs in this forum, but nowhere is there any mention of valve lash. You have got to set'm to do the job right. I found them all over .040 so I just faked it and set them at .010 and .015. I'd like to find the actual specs though. Is there a link to an online reference?
The points were smoked, so I filed'm and set them like it was mine. I'll check dwell after I get it to quit shootin ducks. This bad boy needs some work.
Does anybody out there have a Super Duty Shop Manual where we can read the gospel from the good book?
  #75
Old 06-12-2007, 09:08 PM
534 specs
i have a manual what do you want to know
1966 T850 Super Duty 534 Engine Paint Scheme Harley48 1961 - 1966 F-100 & Larger F-Series Trucks 3 01-08-2015 04:10 PM
534 oil filter swap deere81 401, 477, & 534 SD Engines 0 01-27-2012 05:01 PM
534 cu in fouling plugs fireman336 1967 - 1972 F-100 & Larger F-Series Trucks 8 12-21-2010 07:55 PM
carb for 1974 534 spinach Fuel Injection, Carburetion & Fuel System 13 03-14-2009 04:31 PM
409 or 534 which was better truck engine ? less 401, 477, & 534 SD Engines 1 04-09-2008 04:39 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
534, 880, consumption, diesel, dump, engine, engines, f800, ford, fuel, gas, pistons, seamaster, troubleshooting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
