Any other 534 owners?
Old 12-16-2004, 08:59 AM
doxhog's Avatar
doxhog
doxhog is offline
Hello:
I bought the truck as a collector's piece. Use it in parades, car shows and other fun stuff like that. The truck was just taken out of service in June of this year by the fire department I bought it from. The truck still has the hard suction lines, 2 hose reals, axes, and some lengths of canvas hose. It also has an auxillary pump so that you can drive and pump from the onboard tank (750 gallons) at the same time.
Looking forward to having fun with it.
  #47
Old 12-16-2004, 09:27 AM
150ford's Avatar
150ford
150ford is offline
Sounds great. Good Luck
  #48
Old 12-21-2004, 11:55 PM
wild_louie's Avatar
wild_louie
wild_louie is offline
we farm out here in northwest kansas and around our area there are a bunch of 534's being used as irrigation motors to pump water with
  #49
Old 02-16-2005, 01:51 PM
glennbin's Avatar
glennbin
glennbin is offline
anouther 534
I have an older 37' boat with a 534 ford engine in it. This engine is now turbo-charged. Still looking for Capitol Gear for it. Keep you posted on sea trials.
I have some parts available and original manual
  #50
Old 03-20-2005, 07:11 AM
tkiteasy's Avatar
tkiteasy
tkiteasy is offline
Talking February 05 534 ci
I tried to drive a 68 f-950 bucket truck from New Hampshire to Michigan,it was very slow on the hills(almost got ran over a couple of times.It would have made it except one of the spark plug extension broke open(cracked,and I thought I did engine damage(so we towed it the rest).Got it home and put a new plug in it and its fine.
I truly believe it would have made it saving the expensive tow bill,but we are looking forward to using it this summer,anyhow.
  #51
Old 10-30-2005, 10:29 PM
witdog2020's Avatar
witdog2020
witdog2020 is offline
2 ex-dyno engines
We have 2 older engines that were excellent for low end dyno tests, but didn't have the rpm's we needed so they were replaced with lingenfelter 460's. They will be available for sale in the future I will put them in the classifieds on this forum when available.
  #52
Old 11-12-2005, 06:51 AM
Still in the 60's's Avatar
Still in the 60's
Still in the 60's is offline
Yeah, a retired 62 C850 fire engine, 534, 5 spd strictly for fun, local shows, occasional picnic.
Current project, driveable but not yet complete, a 534 with 5 & 4 stuffed into a 65 F350. something for fun, definitely not practicle or for daily use.
PLus some iron sitting in the shop, some rebuildable, some scrap iron.
Just think the big gas burners from the period are a bit of history to be preserved.
No photo posting capability yet, but I'm working on that.
  #53
Old 11-15-2005, 06:04 PM
Farmall05's Avatar
Farmall05
Farmall05 is offline
I have a 534 in my work truck I cant remeber the year of the truck But hte truck is a tandam axel and it has a 5 speed with a four speed I know one thing it will drink some fuel running the crane all day
  #54
Old 03-10-2006, 07:10 PM
royster's Avatar
royster
royster is offline
534 tractor
I have repowered my Ford farm tractor with a 534 engine, works really well.
The following users liked this post:
  #55
Old 03-14-2006, 12:45 PM
bmc69's Avatar
bmc69
bmc69 is offline
I'm pulling a pair of Seamasters (turbo 534s) out of a friend's old Hateras SF to swap in Cummins V-8 diesels..not sure what we'll do with the 534s but tossing is not an option. They run perfect..he's just plain tired of the points ignition, constantly fiddling with the Holley carbs, and the horrendous fuel bill.
  #56
Old 03-28-2006, 10:43 AM
kmdmb's Avatar
kmdmb
kmdmb is offline
We ran fertilizer floaters for years that ran the 534 or 391. That was tough duty, and we had to keep a replacement on hand. We still have a rebuilt one of each size in the shop if anyone needs one. I don't know what they're worth. We are in SW Minnesota.
  #57
Old 03-28-2006, 06:39 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome kmdmb to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
  #58
Old 10-10-2006, 02:20 PM
Dark Water's Avatar
Dark Water
Dark Water is offline
I just bought a 1965 34' Hatteras Sportfish with the Seamaster 534's. If anyone has any experience or info on these please PM me. THANK!
  #59
Old 10-17-2006, 08:05 AM
WPD388's Avatar
WPD388
WPD388 is offline
Need 534 Info
We Have A Fire Truck With A Rebuilt 534. The Problem Is We Can't Find Any Info To Set The Timing On This Engine. Can Anyone Help. we need this unit online asap.
  #60
Old 10-18-2006, 07:38 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,584 Likes on 1,292 Posts
No responses... too bad. Try 6 degrees btdc. That's what the 289s and 390s regular fuel engines used in the mid 60's. My guess is it will run anywhere between 0 and 10 degrees, and beyond 10 it will ping/knock/blow up.
Quick Reply: Any other 534 owners?
