Gear Splitter? - Ford Truck Enthusiasts Forums
Gear Splitter?
Old 03-15-2004, 02:46 PM
Gunslinger Gunslinger is offline
Gunslinger is starting off with a positive reputation.
Gear Splitter?
Here is another one of those questions, wondering if anyone out there has "been there done that."
I have been offered a good price on a Gear Venders Over/under drive unit (new) and was thinking about doing it. I am running 4:10's now and doing a reasonable amount of towing (32' Fifthwheel). Not that I am having any problems mind you, but it sounds nice. I was wondering if anyone has such a unit on their trucks (not motorhomes) and what their experience has been like?
Old 03-15-2004, 04:04 PM
Colorado-native Colorado-native is offline
Colorado-native is starting off with a positive reputation.
I ran a GV overdrive for 15 years behind a 460 gas motor and a C6 transmission with 4.10 gears. It worked great for that application. It has a gear ratio of .78:1 which gives a final drive of 3.20 with 4.10 gears.
If you have a 5 speed TorqShift, I think that it would be useless except for getting a double overdrive ratio of around 2.24. The TorqShift has about a .75:1 gear split from the factory and I would guess that the 6 speed manual is that close as well so I'm thinking you would be just duplicating all your present gears. If you do get it , do NOT use the GV overdrive for compression braking, it's very hard on the cone clutch in the unit.
Old 03-16-2004, 01:33 PM
$trokin60 $trokin60 is offline
$trokin60 is starting off with a positive reputation.
I read a post on another sight were a guy installed one on a 6.0. He said it didnt have the gear splitting ability, due to the TQ Shift being a close ratio transmission. It only gave him an extra overdrive gear ( double overdrive). he said it brought his rpm down to somewhere in the 1900 @90 MPH range. He liked it and said he would do it again.
Old 03-16-2004, 03:21 PM
Quote:
What gears was he running in the rear end. I have th 4:10 and was thinking of changing them to the 3:73 until I was offered the GV unit. Havent do a thing yet. I notice my gears run about 2000 rpm and just under 65mph. I wouldn't mind having that lower.
Tags
60, 8000, browning, ford, gear, gvc6, pickup, shift, split, splitter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
