Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-15-2004, 01:51 PM
51dueller's Avatar
51dueller 51dueller is online now
2003 Ford Explorer Sport Trac
51dueller is gaining momentum as a positive member of FTE.51dueller is gaining momentum as a positive member of FTE.
Identifying a Mercury Crank
I need help identifying a crank I have. It has 5/8 sludge trap plugs. It it possible to measure the stoke with the crank outside of the engine? Also there is a deep scratch on one of the journals. Would it be worth while to get the crank built up? It already has been ground mains 20 rods 30.
__________________
Nathan
You may have an Effie but I have a Emmie! TM
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
5.4L, AOD, Dana 70 3.73:1, Twin-I-Beam
Built to play and work hard!
  #2 (permalink)
Old 03-15-2004, 06:19 PM
51dueller's Avatar
Never mind. I stuck it in a block and the stroke is 3 3/4.
__________________
Nathan
  #3 (permalink)
Old 04-11-2004, 07:37 PM
dually95 dually95 is offline
Garage is empty, add now
dually95 is starting off with a positive reputation.
Identifying a Mercury crank
It been a long time but I think the 3 3/4 in stroke is a Ford crank. I think the Merc and also the Canadian Monarch were 4" cranks. This is after 49.
Tags
51, crank, crankshaft, flathead, identifying, merc, mercury
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
