fuel tank capacity for 250swb crew cab. 4x4 2000 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-07-2000, 11:19 PM
greg_2 greg_2 is offline
greg_2 is starting off with a positive reputation.
Does anyone know if the ford 39 gal. fuel tank would fit in the short bed,replacing the existing factory 28 gal. tank ?
Would be any easy solution for those owners like me who could use an extra 10 gals. of gas to get a few more miles between gas stations with the v-10.
Tried to order the 39 agl. tank with the truck, but dealer said no.
Quick look at each tank dosen't show much difference. If only the filler hose and mounts will match up. They are approx. same length.
Old 03-08-2000, 10:42 AM
Mark Lanoux
Guest
Posts: n/a
I too would like to put the longbed tank (39 gal) on my short bed to replace the 28 gal tank.
Does anyone know if this can be done?
thanks
Old 02-03-2001, 12:12 PM
chadrock chadrock is offline
chadrock is starting off with a positive reputation.
I am going to Ford today to hopefully get my 2001 F250 V10 4x4 crew cab short bed and I am pretty sure that it has the 38 gallon tank. I will write back later today and let you know for sure
Old 02-05-2001, 01:03 AM
Greg
Well, I got my truck and no, it doesn't have the 38 gal. tank... it has the 28. The dealer told me that the short bed only comes with the 28.
Old 02-12-2001, 01:26 AM
oregonaj oregonaj is offline
oregonaj is starting off with a positive reputation.
You may want to check out the Transfer Flow web site (transferflow.com). They make a 48 gallon replacement for your truck according to their ads.
Old 02-13-2001, 01:53 PM
tripp tripp is offline
tripp is starting off with a positive reputation.
I have the transfer flow 48 gallon tank and I love it.... Will never go back!
Tripp
Old 02-13-2001, 11:32 PM
coloradov10 coloradov10 is offline
coloradov10 is starting off with a positive reputation.
Actual Gas Tank Capacity/Low Fuel Lite sweetoldbill 6.2L V8 14 11-10-2016 09:48 PM
Simplifying fuel system - 90 F150, 4.9L OneLong4x4 1987 - 1996 F150 & Larger F-Series Trucks 3 05-20-2016 08:57 AM
2008 6.4 short bed fuel tank to the 38 gal tank senix 1999 to 2016 Super Duty 4 04-23-2013 02:13 PM
77 Crew Cab Gas Tank DW77 1973 - 1979 F-100 & Larger F-Series Trucks 17 08-24-2004 09:52 PM
Aux Gas Tank muffett 1999 to 2016 Super Duty 5 03-27-2003 01:03 AM
Tags
04, 1997, 1999, 2000, 4x4, cab, capacity, crew, diesel, f150, f250, fuel, size, tank, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
