Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-14-2004, 12:20 PM
Big Mike F150 is starting off with a positive reputation.
Cyl #4 Misfire
I keep getting a Cyl 4 misfire on my '98 F150 4.6L V8. I can feel it in the engine when I'm driving so I know it's there. Plugs and wires were replaced about a month ago and it was running fine for about a week, then it started misfiring. I have double checked the plugs and the wires. I even bought an ignition coil pack for the side with #4 wire/plug and replaced that, and it did not fix it. I'm stumped on this.. Does anybody have any suggestions??
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-14-2004, 01:01 PM
shivelyt is starting off with a positive reputation.
Since you just replaced the wires and plugs, I would start by replacing those first just on that cyl. I've had a new plug that was bad and it looked fine. Good luck.
  #3 (permalink)
Old 03-14-2004, 09:18 PM
krunker is starting off with a positive reputation.
I had a similar problem where I replaced the wires and about two or three days later a misfire developed. Messed with it for about a week and took it to the dealer. Turns out one of the plugs had a cracked insulator and was arcing on the block. Can be pretty hard to see.
__________________
1997 F150 4X4 4.6 Std.
List Mod's in Gallery
FTE
  #4 (permalink)
Old 03-14-2004, 10:52 PM
Thanks. It seems like the cheapest and best route to go thus far. I'll let you know what happens.
Thanks again.
  #5 (permalink)
Old 01-01-2008, 12:35 PM
Nezzer6 is starting off with a positive reputation.
put some sealant around the outside of the boot, keeps the moisture from the ac compressor out. that kills em.
94 ford f-250 4x4 7.3 diesel auto tranny rebuilt by myself
97 f-150 305 auto
01 excursion 4x4 v10
84 f-150 351 winsor 5 speed
  #6 (permalink)
Old 01-01-2008, 06:07 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Make sure the heater hose isn't dripping into the plug pocket. Common on these trucks.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #7 (permalink)
Old 01-02-2008, 05:37 AM
vze2sgxa is starting off with a positive reputation.
What wires are you talking about replacing?
__________________
2000 Expedition EB 4X4/5.4 2V, about 95k as of Oct 2008.
  #8 (permalink)
Old 01-02-2008, 07:05 AM
LxMan1's Avatar
plug wires. 97/98 4.6L have coil packs, not COP's.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #9 (permalink)
Old 01-02-2008, 07:14 PM
Quote:
You mean, the 4.6L engines have full-up actual old style plug wires coming out of the top of the coil packs? Guess I was just confused. The 5.4 doesn't have wires, but I get the 4.6 does.
__________________
  #10 (permalink)
Old 01-04-2008, 09:49 PM
budtrain is starting off with a positive reputation.
i had the same problem....its the fuel injector ...guarenteed..i changed all and ...it is definately the injector
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
