Oil capacity for 4.9L V6 - Ford Truck Enthusiasts Forums
Old 03-14-2004, 08:58 AM
Len-Dogg Len-Dogg is offline
Len-Dogg is starting off with a positive reputation.
Hey guys, I'm new here. I just bought a 1992 F150 Flare Side for a word truck. Seems like a real nice truck! Unfortunately the guy that I bought it from did not have the owner's manual. I searched all around the internet last night trying to find out what the correct oil capacity is for the engine with the oil filter on so that I can change my oil correctly. Unfortunately my search came up empty. I was hoping that if somebody else had this same engine and actually had the owner's manual they could look it up for me. Thanks!
BTW, is there a good site that sells old owner's manuals like the one that I don't have?
-Jason
Old 03-14-2004, 11:15 AM
Bimmer ese's Avatar
Bimmer ese Bimmer ese is offline
Bimmer ese is starting off with a positive reputation.
Welcome to FTE, Jason. The 4.9 litre engine takes six quarts (with a new oil filter) of oil.
You may be able to find a owners manual at a salvage yard, or on Ebay. Another alternative is to purchase a shop manual (eg, Haynes or Chiltons)
Good luck,
Dan
Old 03-14-2004, 12:25 PM
Andyman8282 Andyman8282 is offline
Andyman8282 is starting off with a positive reputation.
4.9 V6's ???
Since when did they make 4.9 V6's?
If your talking about the straight 6, it takes 6 qts of 10w-30 w/ a new filter. I'm told to let her drip for a good half hour, after pulling the oil plug.
Old 03-14-2004, 03:25 PM
jessfactor jessfactor is offline
jessfactor is starting off with a positive reputation.
the haynes manual is cool because it tells you what oil to use for what temperatures. if its below freezing use 5w30. if its going to be warmer than that use 10w30. the oil filter i use is the motorcraft FL-1A.
Old 03-14-2004, 04:35 PM
f15zero f15zero is offline
f15zero is starting off with a positive reputation.
f150 owner's manuals available at www.helminc.com
Old 03-14-2004, 09:05 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
It's not a V-6..it's a straight..(inline) six
Old 03-14-2004, 10:06 PM
Wow that is a lot of oil. I'm used to my miata. :-) I don't think my oil pan can even hold that much at once. Oh well, Thanks!
1980 f350 dually flatbed tow capacity 80duallyf350 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 02-28-2015 10:26 PM
292 Fluid Capacity mcmurb Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 01-12-2015 06:53 PM
'99 Dana 50 oil capacity mwsF250 1999 to 2016 Super Duty 1 10-31-2011 12:46 PM
99 and 05 5.4 oil weight and capacity gtmustang00 1999 to 2016 Super Duty 2 10-28-2009 10:11 AM
Quick question for 1995 302 oil capacity Fordenthusiasts 1987 - 1996 F150 & Larger F-Series Trucks 21 05-16-2008 01:41 AM
Tags
1994, 49, 49l, bronco, capacities, capacity, e150, engine, f150, fluid, ford, i6, motor, oil, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
