part name?
I believe that the temperature sensor on a 4.9L engine is located on the cylinder head at the passenger side of the engine.
Check under the rear-most intake runner where it attaches to the head.
The coolant outlet hose connects a housing at the front of the engine. This gizmo is called a water outlet connection and you remove it to replace the thermostat.
Lou Braun
Lou Braun
The heater pipe, (metal about 10" then rubber 3/4" to core) comes off the WATER PUMP, not the thermostat.
the "coolant" or TEMP sensor near the thermostat is the INTAKE AIR TEMP SENSOR and is located on the #1 runner for the intake manifold.
Lou is correct re: temp sensor itself....it's under the #6 intake runner on the head.
Larry
Larry
Yoda!
1st off instead of yelling why not post a picture of what you're talking about and put a couple of arrows pointing to spots of interest.
I went out and looked at my 93 which is totally different than my old 87 at the thermostat.
What you are looking for is a temperature sensor for the computer. Specifically a Coolant Temperature Sender/Switch
more specifically a GP Sorensen TSU83 or a Wells SU201. These part #'s are from Parts America and Autozone. I'd go for the GP Sorensen over the Wells.
The OEM #'s are ......... O.E.M. #D84Y-12A648-A, DY303, DY681, E0AZ-12A648-A, E1AF-12A648-AA, E1AZ-12A648-A, E4AF-12A648-AA, E6DZ-12A648-A, E6DZ-19E702-A, E80Y-19E702-A, F1AZ-12A648-B, F2AF-12A648-AA, F2AZ-12A648-A, F2VY-12A648-A, F3XA-12A648-A, ZZL0-18-707, ZZM0-18-707
Pull it off and match one of those #'s. If a match then ya got the correct part interchange.
Also there are 1/2 dozen listings for heater hoses. Best thing to do is to remove the water outlet with the hose attached and take it to local parts store. Or drive the truck down there and get one of the guys there to look at what you want. They can match it up easily.
If they don't have exact replacement you can cut the hose off the metal tube (provided that the metal tube is in good shape) and slip a new heater hose over the stub. DOUBLE CLAMP!!!
Timehunter
01-04-2016 07:04 AM
GuitarJesus
09-30-2014 11:21 PM
12a648, 49, 49l, f2af12a648aa, f2az12a648a, ford, heater, location, outlet, pipe, removing, sensor, specification, temp, water
