Intercooler oil leak? - Ford Truck Enthusiasts Forums
Old 03-13-2004, 03:06 PM
jtsmith22 jtsmith22 is offline
jtsmith22 is starting off with a positive reputation.
I took my truck to the dealer to check on an oil leak, and they told that it was coming from the connections of the pipes for the intercooler right over the engine. The leak was very small (3-4 drops in the driveway during a week's time), but I was surprised to hear that the connections could become that loose and that there was that much oil in the intercooler that could leak out and drip. Does this sound right? The truck even seemed to run better when I got it back.
Old 03-13-2004, 04:41 PM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
the crank case vent on the 7.3 is in the intake tube before the turbo. as the turbo sucks air in it will also suck in the oily air from the crank case vent, over time the intercooler pipes and the inside of the cooler will get a light coating of oil on them. if you had one or more lose intercooler pipe clamps it would blow that oil out.
as far as running better, now that the clamps are tight you are not loosing boost out of the system anymore.
everyting they said and the symtoms you had sound right
Old 03-13-2004, 05:10 PM
Thanks - it just seemed odd that enough oil would be pulled through to cause a leak that would run down the back of the engine and drip onto the driveway. I'll keep looking for more spots, but thanks again for the info.
Old 03-13-2004, 05:27 PM
BenRosey BenRosey is offline
BenRosey is starting off with a positive reputation.
wlihntr's comments were perfect.
I am under the impression that the O-rings from the turbo pedastal (bottom and top) are a problem and will be the source of oil leakage. As a result, I replaced mine when I had an unknown oil leak. Since there is a well on the top of the engine, I hope the mechanic took a look at that to rule it out.
2012 2.0L Ecoboost oil leak ? Intake? Scurv Crossovers 0 06-15-2015 02:47 PM
Intercooler in your IDI? Ford F834 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 04-07-2012 06:32 AM
turbo oil leak and intercooler question tgarrisoniv 1999 - 2003 7.3L Power Stroke Diesel 2 03-29-2012 02:20 PM
radiator removal yellow73bb 1999 - 2003 7.3L Power Stroke Diesel 0 06-02-2004 10:46 AM
Oil leak in intercooler yellow73bb 1999 - 2003 7.3L Power Stroke Diesel 6 01-25-2004 11:19 AM
Tags
2000, 2005, 350, 60, 73, diesel, f350, ford, intercooler, leak, leaking, oil, pedastal, pipe, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
