The drain is located on the passenger side of the fuel filter housing. Usually a yellow lever but I have seen them black. Just turn the lever 90 degrees and let it drain for about 30 seconds and you're done.
The drain outlet is on the passenger side and is close to the front of the block.You got to crawl under the passenger side and look for a 1/4" dia.+/- metal drain tube.
Do yourself a favor and cut a length of old garden hose and slide it over the outlet and drop the other end of the hose into a jug.
When you open the drain, fuel splatters on the ground and around the motor if you don't direct it into a container.
