Installing after market a/c in 98' F-250 - Ford Truck Enthusiasts Forums
Old 03-13-2004, 02:51 AM
jjbad jjbad is offline
jjbad is starting off with a positive reputation.
I purchased a 1998 Ford F-250 about three years ago with no a/c in it. At that time I could have had a/c installed for $1150 through an after market installer. For some dumb reason I didn't do it and now I can't find anyone local to do it. Since the truck is over five years old they say it can't be done. I was wondering if anyone knows of someone who might still offer an after market a/c unit? I live in Suisun City, California which is about 45 miles south of Sacramento. I'm willing to drive about 100 miles from home.
Thank you in advance,
Jason
Old 03-13-2004, 12:45 PM
hhott71 hhott71 is offline
hhott71 is gaining momentum as a positive member of FTE.
AC Installation on your truck isn't that hard.
www.bought4less.com has Ac kits for F-150 thru F-900's
call them at 417-623-0515.
If you have a Super Duty truck its real easy install.
If its like a same year F-150 its no harder than changing the heater core.
Old 03-13-2004, 08:21 PM
hhott71,
Thanks for the quick response. My truck is a 1998 Ford F-250 (Lt. Duty) with the 4.6L V8. I emailed "bought4less" already and after speaking to them on Monday I will probably order one.
Thanks again,
Jason
Old 12-31-2012, 02:43 AM
I'm curious,,, Did you find that AC kit as easy of an install as I did? The Super Duty trucks were designed to have AC installed at the dealership. With that kit from Bought4Less, Cruise Control, Auto AC Kits using mostly Ford/Motorcraft parts it all falls into place!!! At least that is what I found
Old 12-31-2012, 05:30 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
You know that post was from 8 years ago....
A/C Quits after radio installation DBRodriguez 1999 - 2003 7.3L Power Stroke Diesel 6 07-10-2014 10:14 AM
Adding A/C to truck daddylee100 1967 - 1972 F-100 & Larger F-Series Trucks 4 11-15-2013 08:31 AM
A/C relay pete98cobra 1999 - 2003 7.3L Power Stroke Diesel 2 05-06-2012 03:02 PM
Nostalgic Air Add on A/C palehorse13 1973 - 1979 F-100 & Larger F-Series Trucks 12 05-02-2008 05:18 PM
Under Dash A/C Units 75 SuperCab 1973 - 1979 F-100 & Larger F-Series Trucks 14 01-07-2007 02:10 AM
Tags
150, 1987, 1998, 98, ac, aftermarket, cooling, f250, ford, install, installing, market, radiator, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
