want to buy a 390, 400, 460 block
Re: Reply
Originally posted by Andresito
It´s a very interesting thing ´cause i found in the door label information that it´s a 354 year 1976
The 354 is probably part of the VIN indicating the style of the truck. Much like mine is a 254.
The VIN number, is longer, and one of the letters in the middle will indicate what motor originally came with that truck. I forget the codes for engines. you should be able to find that in a search here.
If it is an FE (look for 5 valve cover bolts), you probably have a 360 or 390.
I believe there were several engine options in 76. In an F350 you might see anything from a 300 I6 to a 460.
Knowing what motor is in there now will help in determining what to replace it with.
The motors that you listed take different AT trannies, or bellhousings if you have a stick.
You are supposed to be able to swap bell's between the 400m and 460, but I have heard of minor flywheel clearance issues with the bellhousings.
So, if you have a FE and an AT, you won't be able to put in a 460 without changing the tranny too.
I'd say use the same engine family you have in there. It makes it easier. All your listed engines are good, I'm kind of partial to 390's, but the 400 and 460 can be built to make good power too. I'd say go with what's in there. If it's a FE we can answer your questions here in the FE forum.
76 F150 Ranger XLT
25
10-29-2004 11:55 AM
