You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
It means that the cylindar has been bored 0.030 or 0.060 over size in inches. If you look at a foreign car the over size measurements are in mm and are smaller.
It is always better to actually check the bore rather than assume that it is the "book" value + the overbore. On the other hand the book value + the over bore can't be too far off.
I am glad that there is someone else that only remembers pi to 3.14159.(good enogh for govenment work)
GO: Pi (bore)Radius, Squared Height(stroke)
3.14159 X (2.180x2.180) X 3.850 = 57.4808554166 X 8cyl. =459.85cu in
------------------------------------------------------------------------------------ add .060" bore(4.420") makes the radius 2.210" squared =4.8841x3.14159x3.85=59.07378x8cyl=472.6 cu inches
472.60
-459.85
12.75 cubic inch increase in displacement
This would make this big block a real contender in any circle!
Huffer
__________________
1998 "Mountineer" AWD
4.0 SOHC Loaded/ Black
