Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
Closed Thread
LinkBack Thread Tools
  #1 (permalink)
Old 03-12-2004, 12:09 PM
ivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud of
Torque, how 'bout a highboy sticky?
Okay, I don't claim to be any expert on it but at least once a week we see a post where the "what is a highboy" topic comes up, whether it's the topic of the post or just included in a thread. Is there any way we could have a sticky with all the specs as to what classifies a highboy, what years, etc? I don't mean to start a mile long discussion or an argument about it but I think it would be apropos to stick at the top of our 73-79 forum so when people have questions they can read it at the top.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-12-2004, 12:17 PM
Max_'77F250's Avatar
Max_'77F250 is starting off with a positive reputation.
Since i'm here - what exactly is a "Highboy"
  #3 (permalink)
Old 03-12-2004, 05:37 PM
f100beatertruck's Avatar
f100beatertruck is starting off with a positive reputation.
Some where around '75, Ford lowered the F250 about 2-3 inches. People started calling the earlier ones High Boy's... Or so I'm told.
__________________
David
-= 05 Mustang GT - 13.53 @ 104mph w/CAI tune =-
-= 86 F150 - 302 AOD 4x4 =-
-= 93 Mustang Cobra-14.18 @ 100mph stock =-
-= 89 Bronco =-
  #4 (permalink)
Old 03-12-2004, 06:27 PM
OldThumper is starting off with a positive reputation.
Highboys were around until 77....... then they were dropped so to speak
It is truck the rides higher than most trucks .... thus the term Highboy.
The actual Ford highboy is a 32 Ford Model A fenderless car.
  #5 (permalink)
Old 03-12-2004, 06:50 PM
joepickett is starting off with a positive reputation.
The F-250 Hi Boy was built from 67-77.5 it must have 4 inch lift blocks under the rear with dog ears that the ubolts pass thru and a divorced transfer case and they are all 3/4 tons (8 lugs) they came in all trim packages, all motors were available 300-460 4 speeds-c-6s rear axle will be a dana 60 front axle will be a dana 44 you will always see adds that read like this though 1978 F-150 factory hi-boy for sale $9000 this is a f-150 with a lift not a hi boy
  #6 (permalink)
Old 03-12-2004, 07:06 PM
Monster 78 F-150 4X4 is starting off with a positive reputation.
i think a 390 was the bigest motor you could get in a high boy because ford only offered 460's in 2 wheel drives. 460's are a very popular swap for ford 4x4's though
__________________
My Toys
99 Ranger XLT Sport
78 F-150 4X4 460
  #7 (permalink)
Old 03-12-2004, 07:28 PM
BigBuddy is starting off with a positive reputation.
The biggest motor you could get (factory) in a hiboy was a 360 with a 2 bbl. Lots of people think that their trucks have 390's when, in fact, it's only a 360. 390 engines were only in the 2wd's.
IvanRibic is right. Somebody should explain to people. The topic of what a hiboy is keeps coming up far too often. There's no need to scoff at or ridicule fellow enthusiasts that simply don't know (as I've seen done) but, it should be made clear.
By the way, (and on a totally different topic) IvanRibic, is that a Croatian name?
  #8 (permalink)
Old 03-12-2004, 07:29 PM
F150daniel is starting off with a positive reputation.
ford didn't put 390s in 4X4s either.
your options for 73-79 4X4s were 300, 351M, 360, 400.
No 302, 390, or 460.
__________________
815 Cubic Inch Pro Stock Ford Hemi
  #9 (permalink)
Old 03-12-2004, 07:33 PM
Ummmm.....That's what I'm saying. Nothing bigger than a 360 in Hiboy. 390's were only in 2wd's.
  #10 (permalink)
Old 03-12-2004, 07:46 PM
mark a.'s Avatar
mark a. is gaining momentum as a positive member of FTE.mark a. is gaining momentum as a positive member of FTE.
The 400 was in 77's I don't think they ever had small blocks. Just 300's,360, 390. Don't forget the frame was narrowed in the rear.It had the 2 1/2 in. springs in the rear ,and the gas tank was behind the seat.
__________________
'79 F250 13" lift 42" Super Swampers
  #11 (permalink)
Old 03-12-2004, 07:57 PM
76Highboy4x460 is starting off with a positive reputation.
Well then I definitely have myself a highboy
  #12 (permalink)
Old 03-12-2004, 07:59 PM
Quote:
400s are smallblocks, 351Cs big brother.
__________________
  #13 (permalink)
Old 03-12-2004, 08:02 PM
Quote:
I think Yugoslavian but am not certain. I'm all kinds of mixed up.
See what I mean about differing opinions and what's what? I don't have a clue about highboys except what I've read on the forum but for every statement made there are 3 people who will dispute it. Someone's got to have definite details somewhere.
  #14 (permalink)
Old 03-12-2004, 08:07 PM
oops thought i knew more than i thought i did
  #15 (permalink)
Old 03-12-2004, 09:59 PM
I think a safe guideline would be summed up by stating....
A Hiboy is a Ford truck that came from the factory as having the following:
- Built from 1967 thru 1977.5.
- F-250.
- 4x4.
- Divorced transfer case.
Trucks that are NOT considered a Hiboy are:
- Any truck built after mid-1977.
- Anything other than an F-250.
There will always be a couple very oddball exceptions but, for the most part, this is it.
Front axle choices in the Hiboy were either the 8 lug Dana 44 or the old style low-slung pinion Dana 60 (commonly referred to as the Dana 50). Engine choices were either the 6 cylinder or 360 2 bbl. Steering was either manual or, the archaeic and commonly troublesome power ram assist.
Most important to know is that there were no '78 or '79 Hiboys ever built. Secondly, there are no 1/2 ton Hiboys!!! And to clear up the final misconception, there was no such thing as a "factory lift".
Hiboys were not the toughest of all the Ford 4x4's built by any stretch. They had terrible steering and weak front differentials. They, however, looked very menacing due mostly to their stance. These trucks were typically 3-4 inches taller than others produced.
Ivan Ribic had a very good point when he started this topic by saying that this should be stated somewhere. Even people that think they know what constitues a Hiboy are often wrong.
Comments?
Closed Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
