Anyone ever try to put an 80-86 body on 79 frame?
How hard would this be to do? I have a completely restored 86 F150 2wd 8' bed std cab truck without a motor and trans, and my 79 f150 4x4 with a really rough body but excellent running gear and lift. I have been told by some that although thier outer appearance is quite different, that they are actually really close to the same underneath. Other have said only the box will bolt up. Someone else told me that the cab and box will but the front clip won't. I plan to install a 3" body lift at the same time to eliminate any clearance issues (and add some lift for bigger tires ). Let me know what y'all think!
Thanks
DanO
Thanks
DanO
Anything is possible, once you break out the welder and the plasma cutter.
I do know the boxes bolt on, because I have seen them. I really doubt the cabs & clips will, unless you are willing to roll your own mounts.. I think a 3" would be manditory will something like that swap.. Hopefully, someone will have better news than I.
There are another set of bosses on the cab for fitting other frames 150 2&4 to 350 2&4 look in side you will see the blanks. You
may have to mod. a little.
You will have to change the frame ear mounts and fab. them. It could turn in to a little bit of a project but not impossible.
I am in the process of dropping a 90 xlt lariat cab and clip onto an 81 bronco 4x4 frame biggest job so far is floor cut out for transfer case. But even the floor pan is indented where to cut out.
the rad cradle and body mounts workout fine. I had a look at 79 rad cradle and even it would fit in a pinch.
GO FOR IT!!
IF IT WAS EASY WE PROBABLY WOULDN'T DO IT !!!
FLATDECK 82 82 f150 4x4 custom deck and alum boxes one owner 300 I6 built offy dualport 390 holley 3in exh
GO FOR IT!!
on
A bronco puts the rear cab mounts on the outside of the framerails, however, commercial chassis F350's and F450's also do this(you can just swap the x-member to a F150 one and put them where the truck had 'em), and, the 80-96/7 cab is also used on F600 and bigger, so, the cab is drilled for that too...
For a 79/80 mix, the chassis was widened 4" in 1980 so body mounting may be interesting...
The bed should fit, they only re-skinned the old bed in 80, instead of bringing out a complete new one.,
Thanks for all the info guys, I think this project will be a go, just gotta wait for a little warmer weather (cold still up in da U.P. ). Gonna do the 3" body lift, and if need be I will weld up some new brackets to put on the framerails in place of the other mounts. The body I'll be putting on is really nice shape and a nice paint job, so it'll be like having a new truck
Thanks
Dan
Thanks
Dan
mofoco1
08-14-2016 10:49 PM
79f250ranger
08-09-2016 02:08 PM
Gearhead6837
New Member Introductions
04-22-2016 04:47 PM
maddogjohnson
09-06-2015 08:20 PM
