Egr Valve - Ford Truck Enthusiasts Forums
Egr Valve
Old 03-11-2004, 03:53 PM
Ford427Strokr Ford427Strokr is offline
Ford427Strokr is starting off with a positive reputation.
Egr Valve
I was wondering about blocking off the EGR valve on a EFI 302 SD engine. If it would affect the idle or anything else in the engine. And if what all would I have to do to make it work without an EGR valve?
Old 03-11-2004, 04:37 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Why do you want to do that? It won't affect idle if the valve is operating properly, nor will it affect wide open throttle. Why do you want to block it off?
Old 03-11-2004, 08:26 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
I know in chevies you can get in the computer and turn it off, might be possible with fords too, i don't know, just a possibility. By the way, i know this is the wrong site, but i need general info. on my chevy i turned down the EGR to 10 percent in the computer, would i get better gas milage with higher EGR or Lower EGR setting? It goes from 0 to 60 percent.
Old 03-12-2004, 03:58 PM
95 F150 95 F150 is offline
95 F150 is starting off with a positive reputation.
Don't do it unless you want your engine to ping. The EGR reduces combustion temperatures.
Old 03-17-2004, 08:41 PM
The Egr has been blocked off. I havent had any problems. I was just wondering if it could cause any idling problems. I have been told it could.
Old 03-18-2004, 12:21 AM
EPNCSU2006's Avatar
If the valve is stuck open, it can cause idle problems. Otherwise, no.
Does disconnecting the EGR valve effect cooling fan operation? bykr 6.0L Power Stroke Diesel 11 06-24-2016 10:56 AM
EGR Tube Assembly seanseamus1 1987 - 1996 F150 & Larger F-Series Trucks 2 05-08-2016 01:45 PM
Egr valve delete Shawn93 6.0L Power Stroke Diesel 3 06-17-2015 12:59 PM
Egr after an EGR delete pnj442 6.0L Power Stroke Diesel 6 09-29-2010 07:46 PM
EGR valve position sensor JCastellaw 1987 - 1996 F150 & Larger F-Series Trucks 7 01-16-2004 11:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
