Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-21-2000, 09:12 PM
mikehouston mikehouston is offline
mikehouston is starting off with a positive reputation.
Tire Size
I own a 2000 F250 4X4 with the original 16" aluminum wheels with 265X75X16 tires. What larger size of tire will fit the factory wheels and would I need to change my wheels if I wanted 305X75X16 tires. Thanks for the help.
  #2 (permalink)
Old 11-22-2000, 08:19 AM
crewzer crewzer is offline
crewzer is starting off with a positive reputation.
Tire Size
You can check tire manufacturers' websites for wheel width requirements. Your truck's wheels are probably 7" wide -- too narrow for 305's. In fact, if you follow manufacturers' specs, they're too narrow for most 285's.
Changing from 265's to 305's will upset your truck's speedometer and odometer electronic calibration, and may also affect shift points if you have an AT. You might want to consider having a dealer recalibrate your speedo/odo.
crewzer
  #3 (permalink)
Old 11-22-2000, 07:46 PM
PaulL1 PaulL1 is offline
PaulL1 is starting off with a positive reputation.
Tire Size
Your stock rims will fit 305's just fine. Have 295/75/16 BFG all terrain's on mine, no problems and no rubbing.If the speedo is off at all it is so minute that you wont even notice it. The truck looks much nicer with the larger tires.
  #4 (permalink)
Old 12-04-2000, 10:41 AM
mr_scsi mr_scsi is offline
mr_scsi is starting off with a positive reputation.
Tire Size
I have had a problem trying to find replacements for the 265/75R16s those Firestone Steeltex ATs. Why would Ford put a tire on this fine truck that Nobody has a replacement except Firestone. I cannot find any other manufactures that have this size in a Load Range "E".
Anyone else found a good replacement? I have had "radial pull" on the last set of Steeltex ATs and I'm not giving Firestone any more of my money.
Scott.
  #5 (permalink)
Old 12-05-2000, 10:06 AM
Tire Size
Changing the tire size from 265/75R16 to 305/75R16 will cause the speedo & odo to read about 7-1/2% low.
It’s worth keeping the load range designations in perspective. The “E” range for any given tire just means it can be safely inflated to 80 psi, and the manufacturer certifies its load capacity at that pressure. Similarly, a “D” range designation is for load capacity @ 65 psi, and a “C” range is for load capacity @ 50 psi. A tire’s actual load capacity is based on a combination of size and the “load range” designation.
For example, a 235/85R16E is rated at 3,024 lbs @ 80 psi. The 265/75R16E, a larger tire of essentially the same rolling radius and the same “load range”, is rated at 3415 lbs @ 80 psi. The 265/75R16D, a lightly larger tire but with a lower “D” range rating, is rated at 3300 lbs @ 65 psi.
The point here is my suggestion that you determine your load requirements (separately weight the front and rear axles of your loaded truck), add a safety factor, and purchase the correct size and load range to meet your requirements and/or preferences. In addition to the “E” tires, you may find a broad range of styles, prices and availability in the “D” range that are suited to your GVWR.
  #6 (permalink)
Old 01-24-2001, 08:27 AM
Lou19 Lou19 is offline
Lou19 is starting off with a positive reputation.
Tire Size
  #7 (permalink)
Old 03-02-2001, 04:53 AM
idkwhy idkwhy is offline
idkwhy is starting off with a positive reputation.
Tire Size
You seem to be very informed about tire sizes and load capacities. can you assist me with a few questions??
I have a 2001 F-350 Crew Cab with the factory Deluxe Alloy Wheels. I have been told that the Factory wheel for 2001 is an 8" x 16" is that true???
Can you put a 315/75R16 tire on that wheel??
What is the negative inpact of oputting a tire that is larger than the size capacity of the rim??
for example if the factory rim is in fact a 7" x 16 then what is the negative impact of using the 315/75R16 or a 305/70R16??
What is the ture size difference between these two sizes for example???
I would be very appreciative of any assistance you can provide.
Please E-Mail me at IDKwhy(No Email Addresses In Posts!), if you can shed any light on this for me
Thanx - IDK
  #8 (permalink)
Old 03-02-2001, 11:26 AM
Tire Size
[font size="1" color="#FF0000"]LAST EDITED ON 02-Mar-01 AT 11:34 AM (EST)[/font][p]1) To the best of my knowledge, the 2001 wheels are still 16 X 7.
2) BFGoodrich recommends a wheel width of 8 to 10 inches for the 315/75R16.
3) The negative impact of putting a tire on a rim that’s too narrow is that the tire beads are “pinched” by the rim, causing it the tread to curl from side-to-side. Reducing air pressure will flatten the tire, but may subject the tire to excessive heat build up and reduce your fuel economy. Many reputable tire shops won't mount tires on improperly sided rims.
4) The 265/75R16 has a nominal diameter of 30.7 inches (654 revs per mile). The 315/75 is 34.7 inches, or 599 revs per mile. The lowest recalibration setting for the SD speedometer/odometer is either 600 or 601 revs per mile.
The tire manufacturers post a lot of information on their web sites. www.bfgoodrichtires.com and www.dunloptire.com are two good places to visit.
  #9 (permalink)
Old 03-02-2001, 12:44 PM
fishing_maniac fishing_maniac is offline
fishing_maniac is starting off with a positive reputation.
Tire Size
To help answer the question about another brand of tire that is a 265/75R/16 E, I believe that Michelin makes it in a LTS version which is essentially an all-season tire.
My question is: how does the static height of a 265/75R/16 compare with a 235/85R/16? All the specs. that I have seen show that the two are similar but I am concerned that the difference may interfere with the auto's calibrations. I like the look of the wider tire but I wonder if it is worth the headaches?
  #10 (permalink)
Old 03-02-2001, 01:11 PM
ms_scsi ms_scsi is offline
ms_scsi is starting off with a positive reputation.
Tire Size
Anytime you change Tire size you should have the computer recalculated for the tire diameter. Don't forget that this will also change your Gear Ratio.
You can have your dealer perform SSM 11789 & 11790. Besure to find your Revs/mile from the tire manufacturer. This is the critical variable for the reprogramming.
  #11 (permalink)
Old 03-02-2001, 02:25 PM
Tire Size
[font size="1" color="#FF0000"]LAST EDITED ON 02-Mar-01 AT 02:30 PM (EST)[/font][p]Dunlop says the static radius for the AT in size 235/85R16 is 14.7 inches on a 6.5 inch rim; 668 revs/mile. Their 265/75R16 is 14.5" on a 7.5" rim; 678 revs per mile.
BFGoodrich's site doesn't provide static radius data. Their AT TA-KO in 235/85R16 on a 6.5" rim is 654 revs/mile. The 265/75R16 on a 7.5" rim is also 654 revs/mile. Both tires are nominally 31.8" in overall diameter.
I doubt the AT would notice a 1% or 2% variation. I have Dunlop Radia Rover 285/75R16D tires (658 revs/mile) on my truck, and my speedo and odo are low by 3%. I've not noticed any trans performance issues.
  #12 (permalink)
Old 03-02-2001, 02:36 PM
Tire Size
Thanks Crewzer!
I really appreciate your effort!
  #13 (permalink)
Old 03-16-2001, 10:31 AM
homey1 homey1 is offline
homey1 is starting off with a positive reputation.
Tire Size
Crewzer, I was wondering how you like the Radial Rovers?? I am considering them for my 250 4x4 and was curious about their overall performance: how did they affect gas mileage? Are they good in snow?? Any info is greatly appreciated. are they mounted on stock rims? If so, how's the fit?
  #14 (permalink)
Old 03-16-2001, 12:19 PM
Tire Size
One reason I like my AT's is because I got them on sale at Sears last year for $88 each (not a typo)! They look a lot better than the 235/75R16 OEM General tires that came on the truck.
I have them mounted on the stock Y2K XLT 16 X 7 aluminum rims. They're not too noisy for a mild AT tread design, but they were difficult to balance (but we did eventually manage). I have ~12,000 miles on them and they seem to be wearing well and evenly -- I expect to get 50K miles from them.
The AT's are MUCH more comfortable than the stock Generals. I haven't noticed any particular difference in dry weather performance, but they are significantly better in rain. They seem to be OK in snow and light-duty off-roading but I doubt they can compare to real modern snow tires. I usually carry about 400 lbs of sand over the back axle in winter.
Although the 285's are much wider than the stock 235's, they're also a larger diameter. I haven't noticed any difference in mileage. Another size to consider in the AT model is the 255/85R16.
  #15 (permalink)
Old 03-16-2001, 01:10 PM
Tire Size
Wow, I thought I was the only one that got deals from Sears. My take was a set of 4 Dunlop HLT 245/75R16 Load Range E.
The cost - $65.00 Each. They were on their "clearance rack" for 3 Months. They wanted them out the Door.
SM
Tags
2000 , duty , f250 , ford , size , sizes , stock , super , tire , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
