Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 03-16-2001, 04:38 PM
john z john z is offline
john z is starting off with a positive reputation.
Tire Size
A quick one to anyone who knows: If the same size "D" range tire and an "E" range tire are inflated to the same pressure, say 60 lbs, do they have the same load capacity?
  #17 (permalink)
Old 03-17-2001, 04:18 PM
crewzer crewzer is offline
crewzer is starting off with a positive reputation.
Tire Size
>knows: If the same
>say 60 lbs, do they
Yes.
  #18 (permalink)
Old 03-30-2001, 09:41 PM
modcom modcom is offline
modcom is starting off with a positive reputation.
Tire Size
I know that you can fit a 33x12.5x16.5 under the stock setup. I have seen 35x12.5x16.5 under a stock setup , but I don't know how bad it rubs.
  #19 (permalink)
Old 04-02-2001, 12:55 PM
coolcontractor coolcontractor is offline
coolcontractor is starting off with a positive reputation.
Tire Size
>I own a 2000 F250 4X4
>with the original 16" aluminum
>wheels with 265X75X16 tires.
>What larger size of tire
>will fit the factory wheels
>and would I need to
>change my wheels if I
>wanted 305X75X16 tires. Thanks
>for the help.
I have an 01' SD 4x4 crew with the stock aluminum wheels.
I had the 235/85R 16 Generals. They were 30.60" tall and
8" on the tread width. I decided to go with the Bridgestone
Dueler A/T 28575R 16. They are 32.9" tall and only 8.7" on
the tread width. They fit the stock wheels perfectly and do
not rub. My odometer is off (under) by 4 miles for every
100 miles. (shows 96 when actual is 100). I am looking to
raise the front 2" to level off my truck. I have the "crash
bar" that the Excursions have under the front bumper. I want
to retain this bar, but all the leveling kits want to delete
this bar. I am considering going to 315/75R 16 but I hear that
I will need at least a 3" to 4" lift. Hope this helps.
Tags
2000 , duty , f250 , ford , size , sizes , stock , super , tire , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
