NP 205 pto - Ford Truck Enthusiasts Forums
NP 205 pto
Old 03-11-2004, 02:24 PM
fordman300 fordman300 is offline
fordman300 is starting off with a positive reputation.
NP 205 pto
how hard is it to come acrossed a pto for a 205. I can get a 205 for 50 bucks but if its going to cost me an arm and a leg for a pto to run a winch then i cant see the point of having my drivesfafts reworked and doing all the fab work. because i think the m50d will give in before the 1345 does.
but then again front wheel burnouts would be cool
Fordman300
Old 03-11-2004, 02:57 PM
ivanribic ivanribic is offline
ivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud of
Ebay has NP205 PTO's from time to time, I believe under $100. They're not too hard to find. Otherwise buy the case and sell it. $50 for a 205 is a steal. They're getting harder to find all the time.
Front wheel burnouts . . .
Old 03-11-2004, 04:57 PM
Old 03-11-2004, 06:37 PM
I don't have personal experience with PTO's so I couldn't tell you but it looks identical to the other PTO units I've seen. One thing to look out for. I was going to try a PTO on my truck but do not have room due to my exhaust. It runs right past the PTO cover so unless I ran fenderwell exits I couldn't make it fit. Check everything first. I think (might be wrong here) that you'll also need to cut a hole in the bed.
Old 03-13-2004, 05:50 AM
MG86TA MG86TA is offline
MG86TA is starting off with a positive reputation.
Damn i just gave one away and i have another in my garage
Old 03-13-2004, 12:00 PM
Quote:
Why don't I have neighbors like you? One of these days I'd like to pick up a spare so I can experiment with a doubler kit. Everyone is looking for that transfer case because they're tough as nails. The only downside for some people is they don't have a super low gear but it all depends on what you're using it for.
Old 03-14-2004, 12:37 AM
red_rocket's Avatar
red_rocket red_rocket is offline
red_rocket is starting off with a positive reputation.
well, you should actualy have a 13-56 in there now, which you won't break. I would say just swap out your tranny for a real one, and then buy a PTO for that
Old 03-14-2004, 02:07 PM
its a 1345 i checked and a different tranny is just too much work. I bought the 205 yesterday and ill pick it up next weekend. Im going to have to do some real fab work to make some shifters though
Fordman300
Old 03-14-2004, 09:26 PM
73highboy4x4 73highboy4x4 is offline
73highboy4x4 is starting off with a positive reputation.
i bought a new pto unit for my 205 about 5 years agoand if i remember ipaid about $350 for the unit and the cable kit to shift it. i think most pto housings are the same but the gear inside is different to match up to what it is mounted to
Where can I get a PTO shaft for my truck? hail destroyer 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-27-2016 09:36 PM
205 transfer case? fred2001 1999 to 2016 Super Duty 3 01-12-2016 08:49 AM
anyone heard of a PTO winch? jerry73 1973 - 1979 F-100 & Larger F-Series Trucks 16 01-10-2014 01:04 PM
PTO for a NP205 what pump model??? 78fordf150ranger 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-04-2008 10:02 PM
NP 205 transfer case---PTO? Nod Clutch, Transmission, Differential, Axle & Transfer Case 3 11-26-2002 10:19 PM
Tags
1979, 205, constantly, f250, ford, gear, gm, kit, np, np205, power, process, pto, run, truck, units
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
