Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Excessive Egr Flow??
Old 03-10-2004, 11:29 PM
sriggle's Avatar
sriggle
sriggle is offline
Question Excessive Egr Flow??
OK GUYS-- HERE IS A QUESTION FOR SOMEONE OUT THERE!!
CHECK ENGINE LIGHT CAME ON TONIGHT
WENT TO MY LOCAL 24 HOUR A/Z TO HAVE THE CODE READ
CODE CAME BACK AS EXCESSIVE EGR FLOW
WHAT CAN CAUSE THIS??:worm:
THE GUY AT A/Z (WHO I HAVE DEALT W/ FOR QUITE SOME TIME) SAID TO RUN SOME REALLY GOOD CLEANER THROUGH THE GAS.
ANY OTHER OPTIONS????
PS THIS IS ON MY 01 SCAPE- 3.0 W/ 51000 MILES
Old 03-11-2004, 08:24 AM
kws27's Avatar
kws27
kws27 is offline
egr
my dpfe sensor when out on my escape and autozone said it was the egr valve but when I took it to the ford place they told me that it was the dpfe sensor that tells the egr valve to open and close mine was stuck closed I was getting 17mpg after I got it fixed I get 22mpg highway help out alot 63000 on it right now
check your DPFE sensor first before you check your egr valve.
Old 03-11-2004, 09:06 AM
sriggle's Avatar
sriggle
sriggle is offline
thanks- BTW what is the DPFE sensor and how much was it?? That may be it b/c my mileage has been sucking real bad lately
Old 03-11-2004, 09:59 AM
kws27's Avatar
kws27
kws27 is offline
dpfe sensor
i DON'T KNOEW EXACTLY WHAT IT IS BUT I know I was going 240 miles on a tank of gas and now I am going 292 miles and it only takes 13 gal to fill up so if i push it i can probley go 300 miles on a tank it cost me $203.00 to get mine fixed. It help me alot
Old 03-11-2004, 07:53 PM
tsdrallyer's Avatar
tsdrallyer
tsdrallyer is offline
It's been posted elsewhere that you can clean those egr valves to relieve stickiness or other malfuncitons. Try that. Do a search on this FTE site.
Old 03-11-2004, 11:43 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
DPFE = Delta ( or Differential) Pressure Feedback EGR sensor.
It is a small sensor that tells the vehicles PCM (Powertrain Control Module) how much the EGR valve is open.
Check with your dealer as there may be extended warranty coverage on it.
Old 03-12-2004, 03:01 PM
sriggle's Avatar
sriggle
sriggle is offline
Thanks- turns out that there is extra coverage (yeah) I am taking it in tomarrow!
Old 03-15-2004, 07:38 PM
sriggle's Avatar
sriggle
sriggle is offline
Update__ All fixed courtesy of Ford! went in for one thing, came out w/ two things fixed guess they figured out the seat belt need to fixes as well!
Old 03-15-2004, 09:11 PM
bananaboat's Avatar
bananaboat
bananaboat is offline
Did they replace the seat belt buckle with one about twice the size as the OEM? I've heard alot of people complain about the replacements being large.
Old 03-16-2004, 08:04 AM
kws27's Avatar
kws27
kws27 is offline
seat belt
there large and ugly my on the driver side sticks I have to have it seen about
Old 03-16-2004, 11:11 AM
sriggle's Avatar
sriggle
sriggle is offline
They Big, Black and Ugly!! Not Exactly what I expected!! Oh well, guess all I can do is call ford and complain!
Old 03-16-2004, 03:46 PM
kws27's Avatar
kws27
kws27 is offline
warranty
sriggle did they fix your escape under warranty what was wrong
with it was it the dpfe or the egr they did not cover mine under
warranty i have 63000 on mine and it cost me $203.00
Old 03-16-2004, 04:17 PM
sriggle's Avatar
sriggle
sriggle is offline
Ford had an extended warranty on it to 60,000 miles. just lucky mine went out be4 60k! I just put my first tank of gas in so we'll see if it help my MPG!
bbsitum
1997 - 2003 F150
03-29-2012 07:02 PM
Staveys150
03-11-2011 11:55 PM
deejdeej
1983 - 2012 Ranger & B-Series
06-10-2010 09:51 PM
judgebc
01-04-2010 12:50 AM
scott4401
1997 - 2003 F150
04-13-2009 11:24 AM
Quick Reply: Excessive Egr Flow??
