Excessive Egr Flow?? - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 03-11-2004, 12:29 AM
sriggle's Avatar
sriggle sriggle is offline
sriggle is starting off with a positive reputation.
Question Excessive Egr Flow??
OK GUYS-- HERE IS A QUESTION FOR SOMEONE OUT THERE!!
CHECK ENGINE LIGHT CAME ON TONIGHT
WENT TO MY LOCAL 24 HOUR A/Z TO HAVE THE CODE READ
CODE CAME BACK AS EXCESSIVE EGR FLOW
WHAT CAN CAUSE THIS??:worm:
THE GUY AT A/Z (WHO I HAVE DEALT W/ FOR QUITE SOME TIME) SAID TO RUN SOME REALLY GOOD CLEANER THROUGH THE GAS.
ANY OTHER OPTIONS????
PS THIS IS ON MY 01 SCAPE- 3.0 W/ 51000 MILES
Old 03-11-2004, 09:24 AM
kws27 kws27 is offline
kws27 is starting off with a positive reputation.
egr
my dpfe sensor when out on my escape and autozone said it was the egr valve but when I took it to the ford place they told me that it was the dpfe sensor that tells the egr valve to open and close mine was stuck closed I was getting 17mpg after I got it fixed I get 22mpg highway help out alot 63000 on it right now
check your DPFE sensor first before you check your egr valve.
Old 03-11-2004, 10:06 AM
sriggle's Avatar
thanks- BTW what is the DPFE sensor and how much was it?? That may be it b/c my mileage has been sucking real bad lately
Old 03-11-2004, 10:59 AM
dpfe sensor
i DON'T KNOEW EXACTLY WHAT IT IS BUT I know I was going 240 miles on a tank of gas and now I am going 292 miles and it only takes 13 gal to fill up so if i push it i can probley go 300 miles on a tank it cost me $203.00 to get mine fixed. It help me alot
Old 03-11-2004, 08:53 PM
tsdrallyer tsdrallyer is offline
tsdrallyer is starting off with a positive reputation.
It's been posted elsewhere that you can clean those egr valves to relieve stickiness or other malfuncitons. Try that. Do a search on this FTE site.
Old 03-12-2004, 12:43 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
DPFE = Delta ( or Differential) Pressure Feedback EGR sensor.
It is a small sensor that tells the vehicles PCM (Powertrain Control Module) how much the EGR valve is open.
Check with your dealer as there may be extended warranty coverage on it.
Old 03-12-2004, 04:01 PM
sriggle's Avatar
Thanks- turns out that there is extra coverage (yeah) I am taking it in tomarrow!
Old 03-15-2004, 08:38 PM
sriggle's Avatar
Update__ All fixed courtesy of Ford! went in for one thing, came out w/ two things fixed guess they figured out the seat belt need to fixes as well!
Old 03-15-2004, 10:11 PM
bananaboat bananaboat is offline
bananaboat is starting off with a positive reputation.
Quote:
Did they replace the seat belt buckle with one about twice the size as the OEM? I've heard alot of people complain about the replacements being large.
Old 03-16-2004, 09:04 AM
seat belt
there large and ugly my on the driver side sticks I have to have it seen about
Old 03-16-2004, 12:11 PM
sriggle's Avatar
They Big, Black and Ugly!! Not Exactly what I expected!! Oh well, guess all I can do is call ford and complain!
Old 03-16-2004, 04:46 PM
warranty
sriggle did they fix your escape under warranty what was wrong
with it was it the dpfe or the egr they did not cover mine under
warranty i have 63000 on mine and it cost me $203.00
Old 03-16-2004, 05:17 PM
sriggle's Avatar
Ford had an extended warranty on it to 60,000 miles. just lucky mine went out be4 60k! I just put my first tank of gas in so we'll see if it help my MPG!
EGR Issue ben158 6.0L Power Stroke Diesel 5 11-20-2014 12:58 PM
P0401 and P0402 codes Staveys150 1987 - 1996 F150 & Larger F-Series Trucks 3 03-12-2011 12:55 AM
2001 escape p0402 code need help techsuphunt Escape & Escape Hybrid 4 05-01-2008 11:28 PM
DPFE or EGR Valve Position Sensor on 97" ranger 4.0L oudeisman Ranger & B-Series 2 12-15-2004 10:02 AM
EGR Valve Replacement and Autozone darth 1999 to 2016 Super Duty 16 09-18-2003 09:14 PM
Tags
2002, 2003, 46, dpfe, egr, egrdpfe, escape, excess, excessive, exsessive, flow, ford, pressure, sensor, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
